Xfer case shift lever question
Old Dec 10, 2008 | 04:33 PM
starflite3's Avatar
I have a queston on the later model shift levers for the transfer case.
I am going to put a 2000 model cab on my 95. After reading about the problems doing an auto to 5spd swap using a newer trans. I need/want to use a newer style floor mount xfer shifter.
I am wonderng if I can use one from a 1/2 ton truck.
Are they the same as for the 3/4 and ton trucks? Or do I have to find one from a diesel?
Also how are they attached to the xfer case as far as shifting mechanism?
Cable or rod?
Thanks.
Also, is there a tutorial on posting pictures?
I am going to take a lot during this change over.
Would like to share some, maybe benefit others considering similar swaps.
Old Dec 10, 2008 | 07:29 PM
Big Deezul's Avatar
its a rod to the xfer case...I would assume the shifter itself would be the same gas or diesel as long as it has the same xfer case
Old Dec 10, 2008 | 10:23 PM
dozer12216's Avatar
Big Deezul is correct.
bucknasty
Feb 2, 2009 08:46 AM
4x4dually
May 7, 2006 11:02 AM
guidster
Jun 6, 2005 11:16 AM
roadranger
Jul 12, 2004 10:43 PM
xzlram
Feb 18, 2004 07:01 AM
