White smoke when my 96 starts up?HELP
Old Jul 1, 2008 | 12:56 AM
12valvesmoker's Avatar
When I start my 96 12 valve up it blows out white smoke then black smoke. It has just recently been doing this and only on the first start up of the day. It acts like it's clogged up or something. I have no modifications done to the truck. It's completely stock and I want to get this problem fixed if I can. Thank you.
Old Jul 1, 2008 | 01:13 AM
Does anyone think that I could be getting air some how into my fuel? Do you think that I could replace my fuel lines and it would be solved?
Old Jul 1, 2008 | 10:35 AM
Fueling around's Avatar
Do you have to give it some go pedal to start?
Sure sounds to be a bit of air. Before you replace fuel lines, look for the basics. Recent fuel filter change or been adjusting something?
Old Jul 8, 2008 | 10:18 PM
yes i do or it will stall out but after I give it gas it cleans right out.
Old Jul 8, 2008 | 10:44 PM
I just went through the same problem. It got so bad I had to use the primer button for every start. I found a rolled gasket on the fuel heater I replaced in January.
I suggest going through the entire engine side first before jumpin on the fuel lines. Start with the prefilter & fuel heater..
Old Jul 9, 2008 | 11:07 PM
tom25's Avatar
could be several things but try changing your fuel filter first if you havent already.
TXlilbro
Jul 29, 2010 06:37 PM
97catintenn
Jan 7, 2010 11:33 PM
BlackSheep5
Nov 27, 2006 07:52 PM
mr T
Sep 11, 2005 10:51 AM
dhe9
Nov 14, 2003 07:31 AM
