white smoke and shaking after cold night starts
after a cold night...i start the truck it smokes white out the stacks and the truck shakes for about 5-10 sec and then smoothens out...after that everything is fine and there's no more smoke...it doesnt smoke otherwise...i dont get high rpm misses or smoke....
the lines are all good...truck has no leaks...fuel filter is a month old
the only thing left thats never been done in 2 years since i got the truck is the overflow valve and timing....would those be the main things? it should be an just a worn out overflow valve shoudlnt it?
A little white smoke is normal in cold weather. Cold combustion will cause both smoke and rough running till all the cylinders kick in. As long as it goes away in a short amount of time. One thing that can make it worse is retarded timing. It gets a little better with timing increase.
yeah i figured that...i always thought that high rpm misses is "timing" and low rpm misses is the overflow valve....that was always my general thinking...but i guess getting both adjusted wouldnt hurt...i'll get the overflow valve for 30$ from marty precision injection diesel i think it is...i'll find it
Interesting reading here:
http://www.dodgeram.org/tech/dsl/maint/2nd_Gen-12v.htm
And here:
http://dodgeram.info/tsb/1996/14-07-96.htm
And here:
ok good...its been going on ever since i bought it...has never gotten worse...i was just curious about it...Bill since you're hangin around...i postend a question about my 3 k gsks...i was just curious as i was reading about the wastegate..umm do i get enough boost in the higher rpms now that i have the gov springs? i dont get any smoke up there or anything..was just curious...alot of guys close to stock or just a bit more fueling than stock disable it dont they?
I have the wastegate hose disconnected and plugged on my truck. I can now get up to 28 or 29 PSI at higher RPM with the 3K GSK. With the wastegate connected I could only get 18 PSI. I have read here that the turbo is OK up to about 35 PSI - if you can get there (need more fuel).
hey sidewinder i dont exactly get how to plug it though...cant i use a hose clip and just pinch the hose coming off the afc?..im reading and there's all these weird ways of doing it...some of the new truck guys have some odd belts and chains accross their turbos
One thing to check about the white smoke issue is that BOTH preheater grids come on before you start it. If a relay goes bad, you'll only get half the heat into the engine and you will get those symptoms.
Regarding the wastegate, instead of disabling the actuator completely, you can adjust the rod, and set it to any max. pressure you want.
To disable the wastegate all you need to do is disconnect the line from the turbo. You only need to plug it to prevent a pressure/vacuum leak. I disconnected it on the top of the motor near the intake manifold - rubber vacuum line. I just found a bolt that fit inside the line, stuck it in and put a hose clamp on it to make sure it doesn't come out.
97catintenn
Jan 7, 2010 11:33 PM
12valvesmoker
Jul 9, 2008 11:07 PM
crash4wd
Dec 17, 2007 08:48 PM
big red psd cc
14
Sep 1, 2004 01:39 PM
