Where is this "hand pump" everyone talks about..
Where is this "hand pump" everyone talks about with a fuel filter change. There is no plunger or anything like that in my 98 12v. This is getting VERY frustrating.
the thumb pump down by the fuel heater on the drivers side of the block behind the p7100 on the side of the block about midway maybe a little lower it has a black rubber cover. follow your fuel lines you cant miss it.
99globalwarmer, thanks! I found it about 30 seconds after reading your post.
Infidel, With that diagram, I would have found it 10 seconds after.
I really appreciate y'all stepping up.
How often should the water be drained and how much should be drained out? I did this once at a fuel stop with the engine shut off and the truck wouldn't re-start. Used the primer a bunch of times and got it going but it made me think I didn't do it correctly.
Whats the best procedure to keep this from happening and still keep water drained off?
It drains fast without problems if you do it with the engine running.
Eskimo
17
Oct 26, 2004 08:56 AM
