Whats up with the hieght proportioning valve
Old Mar 24, 2005 | 01:41 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
http://dodgeram.info/tsb/1998/05-04-98.htm
I dont get it. my ford didnt have anything like this and with the Dana 80 rear and large wheel cylinders and the disks front it functioned just fine for my application whats the differentce between the Ford and my 2500 dodge.
They say 75% of GVW is that just for the truck? in that case stock my truck is 7050 of an 8800 lbs gvw that means im 80% of GVW already What gives here. i dont forsee any adverse problems if i remove it.
Old Mar 24, 2005 | 07:19 PM
RCW's Avatar
RCW
Just about every light truck with an over 7200 GVW, sold since 1984, that does not also have full anti-lock brakes, also has a load compensating brake proportioning valve installed on the rear axle for safety purposes. The idea is to increase the brake loading and line pressure on the rear wheels in proportion to the load, as determined by the height of the truck relative to the rear axle (amount of suspension compression is the determining factor). It keeps light trucks from locking the rears and then turning a 360 when you hit the brakes.
I would suspect your Ford was really old, or had full anti-lock brakes, or was a light duty F150.
Old Mar 25, 2005 | 10:33 AM
ddestruel's Avatar
97 F-250HD diesel cummins diesel that was
thank you i was just currious RWAL and my dodge has RWAL so i was trying to grasp why they would do the valve and RWAL.
Ah yes i remember the old Power Wagon days
Boatnik
Mar 16, 2006 01:57 PM
Superduty12v
22
Nov 6, 2003 04:17 PM
