What would cause this?
Right now my truck stumbles pretty bad from 1900-2400 give or take rpms when trying to accelerate. Its a 96 with 215 pump. I just installed a HTT 64/71/13 and 7x.010 injectors. It was also doing it with the 370's but figured it was just the injectors. My timing was set at 16.5* but I'm guessing its slipped and it causing this. I'm going to adjust the timing somewhere between 20* and 24* next week after I get back from this trip.
Thanks for any input.
Fuel filter, overflow valve and finally delivery valves. Depending on the injector, you may need them as I know standard 370s will stumble in that RPM range. Timing that far ahead isn't really good unless you are planning to start sled pulling.
wilderness
Oct 17, 2006 02:38 PM
Tree DR
17
Apr 29, 2006 10:21 AM
bigbaddiesel
Nov 30, 2002 08:17 PM
