what axle 70/80
what axle 70/80
sorry for a stupid post but i'm thinking of buying an axle to change my truck to 3.55's from 4.10 the truck it is out of is a 1994 dodge ram 2500 4x4 hd turbo diesel 5 speed stick.
i beleive what i have is a dana 70 and this is a dana 80 as far as i know it will bolt in are there ANY bolt up differences u-joint size or snout length i should worry about?
Thanks
Brandon
Thanks
Brandon
I think everything will bolt up just fine, you should have a dana 60 in the front and a dana 80 in the rear right now since yours is a 5spd, the auto tranny trucks came with the same front axle and a dana 70 rear axle.
Originally Posted by mr_ed
but is it a problem if one puts a 5-spd in an auto truck and leaves the d 70?
But since you have that many miles, next time you do a diff oil change look for bearing material, because D70's like eating diff carrier bearings.
From: Ordered to Elizabeth City NC. rather be back in north Idaho
What kind of length difference are we talking with the pinion snout? Cuz when I swap trannies I'm going to have to get different driveshafts (off a manual truck) and if I do that then that rear shaft will have been designed for a D80. If I retain the D70 until the "cool stuff for the truck" coffers fill up again, is it going to overextend the shaft?
well i purchased the axle and to fill everyone in there are a few differences the pinion snout is longer and i did get my drive shaft to mate to it but felt like the slip yoke was very compressed. the axle tubes are larger diameter on the 80 and require longer u-bolts and modification to the bottom plates that hold the u-bolts. my truck has a sway bar and load control for the brakes which the new axle does not have mounts for.
so i have a few questions my new 80 has one of the tabs broken off of the pinion yoke that retains the u-joint i plan on replacing the yoke and was wondering if the 70 and 80 pinion yokes are the same and if they are i am also wondering if the 80 uses a crush sleeve or shims to set pinion pre-load.
second how do they attach a rear sway bar to trucks equipped with a Dana 80 my 70 has longer shock mounts that double as mounts for the sway bar but the 80 only has enough room for the shock i was planning of cutting the brackets off of the 70 and putting them on the 80 unless there is a bolt on option that the 80s use for a sway bar.
thanks sorry for the long post
Brandon
Brandon
When I put my 80 in my truck I had to shorten the driveshaft 1 1/2 - 2 inches
The 70 and 80 yokes are different I had to replace one of those too
The 80 has a much larger pinion and it uses shims
stealman1
May 6, 2008 08:05 AM
ridofpwrstroke
Aug 25, 2006 05:24 PM
MX429
Aug 20, 2006 06:41 PM
04ctd
Apr 5, 2005 11:59 AM
