weird smoke?
Old Jun 11, 2010 | 09:33 AM
arroyojim's Avatar
weird smoke?
not sure the best way to describe this....
when accelerating, usually with a load or up hill but not always,
there will be some smoke which i figure is normal,
but then occasionally there will be a quick puff that blows out bigger
and darker than the steady stream which i figure is normal..
make sense?
this doesn't happen often, but i'm concerned about what causes it.
Old Jun 11, 2010 | 10:13 AM
infidel's Avatar
Bump in the road makes your right foot jump a bit?
Old Jun 11, 2010 | 04:47 PM
Lil Dog's Avatar
May also be an early indicator of a sticking injector. I had that issue with an older truck of mine, an 89. But it would be at WOT where I would notice the nice grey haze would have puffs of black that would fill a 5gal bucket. It was finally found that an injector was sticking.
Old Jun 11, 2010 | 05:04 PM
arroyojim's Avatar
i rarely floor it, but it is usually only under pretty heavy acceleration...
are there any other symptoms of a sticking injector?
Old Jun 11, 2010 | 05:12 PM
arroyojim's Avatar
also, i do notice some additional smoke when pressing on the pedal, but this is different. it's like a real quick burst of smoke above and beyond the normal exhaust, and without any changes in acceleration or sound or anything...
Old Jun 11, 2010 | 08:06 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
These old mechanical trucks need to be "beaten on" once in a while to keep things clean(no joke). Might want try that if nothing else seems to help.
illEatUrDuramax
Nov 30, 2010 05:51 PM
Common
Apr 9, 2008 10:25 PM
PK
Oct 19, 2003 10:28 AM
jbs007
Jul 8, 2003 01:29 AM
97CTD
Mar 17, 2003 08:14 PM
