Weak fuel solenoid??
Old Jan 30, 2006 | 12:39 PM
SHARPMACHINE's Avatar
My truck began to take a second or so to shut off over the weekend. A couple of times I had to turn the key on and manually lift it before starting it. It would start for a second, then quit until I manualy lifted it.
thanks
Old Jan 30, 2006 | 01:25 PM
nutman's Avatar
Solenoid
yup,sounds like the solenoid,But??? shutting off usually isn't the problem.there are some good posts in the help section,i just replaced mine.
start quit start quit ect.ect.,mine would't hold open.hope this helps..
Old Jan 30, 2006 | 06:20 PM
bmoeller's Avatar
Sounds like you may need to lube the throttle linkage, if it is taking a bit to shutdown.
Old Jan 30, 2006 | 06:52 PM
kandgo's Avatar
Take it off and clean it and see if the boot is rotted out, if so clean and lube and use a bicycle tube as a boot and exhuast that effort first, then check the relay,wiring and adjustment before throwing a new one on as they are pretty tough. Goodluck,,Rick
Old Jan 31, 2006 | 07:39 AM
thanks
I am going to try cleaning it and lubing the linkage to see if that may help or band-aid it for a while. Hopefully it works because it looks like they cost $200. - ouch.
any other ideas please post
Old Jan 31, 2006 | 10:45 AM
infidel's Avatar
About the only time the solenoid needs replacing is if it's visibly burnt up on the outside.
The solenoid is probably the single most needlessly replaced item on a 12 valve.
Most always the problem is a corroded blue wire at the battery, bad solenoid relay or rusted, gunked up linkage or solenoid plunger.
dodgediesel
Apr 15, 2010 09:00 PM
dj_souvlaki
Feb 27, 2008 06:46 PM
realsquash
Feb 5, 2007 05:57 PM
mopar2ya
Aug 26, 2004 12:23 AM
BigBlock
Feb 11, 2003 05:41 PM
