Valve cover gaskets
Old Apr 30, 2005 | 04:25 PM
Burrito's Avatar
Valve cover gaskets
When I bought my used truck I noticed oil around the valve cover gaskets. I cleaned the top of the engine and replaced the gaskets. I am slowly starting to see a little oil around the gaskets. What's the deal here?
Old Apr 30, 2005 | 05:51 PM
Clucker's Avatar
You have a leak?
Old Apr 30, 2005 | 06:02 PM
bmoeller's Avatar
Have you retorqued the bolts? 18 ft/lbs. Did you replace the o-rings that are under the bolt heads, at the same time?
Are the valve covers seated properly? How long since you replaced the gaskets?
Old Apr 30, 2005 | 08:52 PM
Burrito's Avatar
I did replace the o rings at the same time. I'm pretty sure they are properly seated. I don't have a torque wrench, but I got them good and snug. I might double check that though. Any other thoughts?
Old Apr 30, 2005 | 10:59 PM
infidel's Avatar
You really should use a torque wrench, too tight is just as likely to cause leaks as too loose.
capt.Ron
16
Jul 13, 2006 03:24 PM
mt72916
Jan 18, 2005 09:43 PM
LanceD
Jul 6, 2004 01:32 PM
srowen
Jun 27, 2003 06:44 PM
mymaur
Dec 23, 2002 08:28 AM
