vaccuum leak... again
Old Nov 28, 2007 | 08:33 PM
48snowman48's Avatar
Is it possible to have a vaccuum leak and not have any problems? I have been getting blowby horribly for a while now, but the truck runs great. I fixed the cruise control line that was leaking, but it didn't solve my problem. The truck goes into 4wd with no problems. I am definitly hoping that my blowby is due to a vaccuum leak, but it is totally possible that this isn't the case at all. I am dumping oil into the truck at a rate of about 1 gallon every 250 miles, which can get very expensive since I drive about 550 miles per week.
Old Nov 29, 2007 | 10:07 AM
infidel's Avatar
Very easy to check for a vacuum leak. Run the engine for a few minutes to build vacuum shut it down and wait a few minutes. Disconnect any vacuum line, if it doesn't hiss you have a leak.
An engine with no leaks will hold vacuum for several days if not weeks.
Old Nov 29, 2007 | 11:21 AM
lgp9999's Avatar
Good to know. I was not aware of that. I think I have a vacuum leak as well.
Old Nov 29, 2007 | 06:03 PM
Tried disconecting a line, no hissing. What is the best method to determine the location of a vaccuum leak? Thanks.
Old Nov 29, 2007 | 06:12 PM
infidel's Avatar
Buy an inexpensive vacuum pump with gauge from the autoparts and start disconnecting then pumping down hoses one at a time. The one that leaks down rapidly has a leak.
Old Nov 30, 2007 | 07:58 AM
T-Bone's Avatar
The MityVac from Harbor Freight works great for me!
T-Bone
Old Nov 30, 2007 | 09:59 AM
infidel's Avatar
T-Bone
That one doesn't have a gauge, here's one for half the price that does http://www.harborfreight.com/cpi/cta...emnumber=92474
Old Nov 30, 2007 | 10:13 AM
T-Bone's Avatar
Oops! My bad. I actually have one with a gauge. On special it was ~$25. Bill, thanks for the link. It looks like a much stouter tool.
T-Bone
Old Dec 3, 2007 | 01:53 PM
Thanks for the good info, Does anyone have a diagram (sort of schematics) of the vaccuum lines on this truck? I am at school during the week and am either in class or working during daylight and don't have a very good place to work on the truck. Is there just one line coming from the pump or is there a return somewhere?
DodgeRamdiese01
Jun 19, 2009 12:13 AM
guitarman
May 3, 2009 11:21 AM
Trace
Dec 13, 2007 08:28 AM
lawnman757
Nov 6, 2003 04:21 AM
fitzer
Sep 3, 2003 09:53 PM
