U joints
Old May 17, 2005 | 12:11 AM
running4bhs's Avatar
U joints
Well I did some reading and it seems that everyone here likes to go with the spicer U joints for my truck. I would like to know where I can buy some becuase I was told that I should replace those and an oil gasket that goes in the rear end because it is leaking rear end fluid. Anyone know anything about this that they would like to share with me? Thanks guys
Old May 17, 2005 | 11:14 PM
farmer dave's Avatar
You should be able to get spicer u-joints at any parts store. If they don't have them in stock they should be able to order them.
Old May 17, 2005 | 11:40 PM
I have tryed and none of the parts stores here carry them. I have a Dana 70 rear end I belive. Anyone have any ideas?
Old May 17, 2005 | 11:47 PM
Hemi Cat's Avatar
Try NAPA or go on line to quad 4x4.
Old May 18, 2005 | 12:00 AM
napa doesnt carry them
Old May 18, 2005 | 10:16 AM
infidel's Avatar
They did last Saturday when I replaced both joints on a '97, they even had them right in stock.
I've bought rear axle seals from Napa also, I thought they were on the expensive side though at $17/ea
Old May 18, 2005 | 06:51 PM
Ok thats strange I went to napa and he told me that they dont stalk spicer U joints so I said "ok thank you sir" and left. I found a driveline shop that can order them, but I dont know what size I need. I have a Dana 70 rear end I think and they told me to take the U joint off bring it in and they will order it. Any one have any info on this??
Old May 19, 2005 | 09:42 PM
This seems very strange that you can not find a parts store that carries spicers. Have you tried the dealer? They may be expensive, but you should be able to find out what size you need from them. Also, look at http://www.discountautoparts.com they have alot of stuff, you should be able to find some u-joints.
Old May 20, 2005 | 08:27 AM
CTD NUT's Avatar
Your D70 rear should have a Spicer 1410 series (external clip) rear driveshaft u-joint size...that is all the info the driveline shop needs to know to order the correct u-joint and don't bother with a gasket for the diff cover - even the factory just uses silicone on them these days.
kprc51
Jun 14, 2007 06:27 AM
njmaier
15
Jul 26, 2006 07:43 AM
getblown5.9
May 2, 2006 10:01 PM
Seeder
Feb 15, 2006 08:15 PM
Dynocon
Mar 5, 2005 06:24 PM
