U-Joint Quality question
Old Jun 14, 2005 | 02:11 AM
CmminsBeast's Avatar
Any suggestions on a certain brand of u-joint to buy, or stick with factory? going to replace a couple and wondering which is best for the money?
Old Jun 14, 2005 | 07:10 AM
redramnc's Avatar
I have always tried to find the Dana/Spicer joints with the grease fitting in one cap for replacing driveshaft joints. Depending on clearance the zerks may have to be pulled and a plug installed if they are on the drive axles up front.
That said I have used whatever brand was available and have never had any problems. Just make sure they are greased well and often enough. It also helps to have a ball joint press tool to use on removal/installation of u-joints - the ability to slowly press and make sure everything is in alignment makes the job much easier. Compared to hammering new joints back in a press is the ticket.
Old Jun 14, 2005 | 03:14 PM
B-rock's Avatar
Dana/spicer. Only u-joints to get IMO. Go to harbor freight and get there u-joint/ball joint tool.
Old Jun 15, 2005 | 09:55 AM
apache's Avatar
Dana`s only!!!! or youll be replacing them again. Our local Napa carries them, or try on line sources.
Old Jun 15, 2005 | 08:34 PM
MR HYDROSEED's Avatar
I just bought one at autozone
I just bought one at autozone and only bought it because it has a lifetime warranty on it. it was the brute strength one and didn't have a grease fitting. But i said what the hell $17.99 and lifetime warranty, why not. How much is a Dana u-joint?
Old Jun 15, 2005 | 11:32 PM
12vordie's Avatar
A little fact that anyone with racing or hard core 4x4 histury will agree is that the ones without the grease fitting are stronger than the ones with grease fittings, they may not last as long, because you can not grease them but they are stronger.
Old Jun 16, 2005 | 08:31 AM
TxDiesel007's Avatar
I agree with you vordie
I have SNAPPED my rear u joints before in four low.. how that happened i dont know, an old mechanic friend told me for stregnth at the sacrifice of longetivity get the ones without the bearing, i do have one right now that i bought at a local (not mainstream) parts store in town and they work well..
Tx
Old Jun 16, 2005 | 07:41 PM
B-rock's Avatar
If you want absoulute no questions asked strangh then I would go with CTM's. But those go in your front axle. They are without a doub THE absoulute strongest u-joint made. Stronger then the factory dana/spicer axles. But if you want driveline u-joints then I would recomend cryo- treated dana spicers. Then your weak link is no longer an easy to fix and cheap u-joint.
Old Jun 19, 2005 | 10:24 PM
Crimedog's Avatar
sealed, genuine Dana Spicer is the only way I go. The stockers lasted 165K, I can handle paying 50 bucks per U joint if they last that long. That was in the fronts, I haven't done anything with the drive shafts yet...
72dart
Jun 19, 2012 10:42 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
mkeanglorldo56
Dec 27, 2006 10:53 PM
