Turbo exhust elbow ?
Old Feb 3, 2026 | 11:41 PM
oldblues's Avatar
Question Turbo exhust elbow ?
hi ,
is there a turbo exhaust elbow that will bolt to my 1998 12 v hx35 that goes directly to a 4" exhaust pipe ?
current factory one is 3" so p[ipe is necked down from 4" to connect to turbo .
i want to install new ex system 4" direct to 4" pipe .
who has this new or used ?
part no ?
THANK YOU !
Old Feb 4, 2026 | 05:58 AM
u2slow's Avatar
you have two factory options:
- the short/flat outlet thats a hair over 2.5" ID (94-98?)
- the 98-02 cast elbow that i think youre describing
otherwise there is aftermarket
https://pacbrake.com/c44083-pacbrake...elbow-kit.html
Old Feb 4, 2026 | 01:17 PM
dguru's Avatar
I know many people will say different but switching to a larger exhaust with the stock turbo and stock injection system will actually hurt drive ability. You will lose low end torque. The difference is noticeable. You only benefit from larger exhaust if you plan to run a different turbo or run higher RPM with HX35. Higher RPMs are sort of moot with a stock automatic transmission.
I am not sure of part numbers but you can buy flange and elbow then weld them however you want.
Old Feb 6, 2026 | 07:07 AM
I have the turbo elbows you speak of in my shop. They clamp on the back of the turbo then two bolts hold them to the exhaust down pipe flange.
Old Feb 6, 2026 | 08:41 AM
u2slow's Avatar
this is the later style.... bolts on... not sure what OP has
https://www.dieseltruckresource.com/...flange-299516/
Old Feb 6, 2026 | 10:30 AM
U2slow,
I was picturing he had the ‘98-‘02 style. Which is expensive through Cummins.
Not the version you had a link too that bolts on too the back of the turbo with 5[?] bolts
I have several of the ‘98-‘02 style, which I believe he needs.
Old Feb 6, 2026 | 04:37 PM
u2slow's Avatar
U2slow,
I got the bolt-on one from an '02 (7-blade hx35) and the clamp on style (2-piece) from 94-95.
Old Feb 7, 2026 | 10:51 AM
Cool. Now if the OP ever checks back in he has lots of options.
82ndVet
14
Jun 5, 2022 04:01 AM
wyattearp29
0
Jun 11, 2009 08:48 PM
1985cucv
Mar 28, 2009 04:46 PM
NHDiesel
Dec 23, 2005 05:36 PM
gullydog
Mar 10, 2005 09:10 PM
