truck starts then dies tried relays new solenoid please help
Old Sep 9, 2006 | 12:53 AM
twisselman1968's Avatar
Exclamation truck starts then dies tried relays new solenoid please help
I'v got a 97 that wouldn't start a few weeks ago so I put a new fuel solenoid on it two weeks ago and everything had been great but today I was going down the road and the truck died. It would start back up but died as soon as I let of the key so I got a stick and wedged in to hold up the fuel shutoff solenoid and started it but the truck would not shift or charge, I had no electronics so did I frag a computer or a power feed to the pcm or what, I have power to one poll on the hold relay for the solenoid but can't find a wiring schematic for the smaller hold relay can I get some help please I'm losing my mind with this truck...any help thanks
Old Sep 9, 2006 | 01:10 AM
Moparmax's Avatar
twisselman1968,
My 98 did the same thing. Check the fuse panel in the Cab. Mine was blowing a fuse all the time. Would crank and catch but died as soon as you let go of the key.
I don't have the truck here to tell you which one to check, Sorry. I belive it is the 10 amp. Turned out that I had a wire that had been rubbing on the ABS module for the last 200k. Re-wired that one and have had no more troubles.
HTH
Moparmax
Old Sep 9, 2006 | 10:21 AM
infidel's Avatar
I've run into a bad key switch that caused the same problem.
The switch is availible at Napa.
You will also need a torx security bit to remove it, sorry don't remember the size.
Old Sep 9, 2006 | 11:55 AM
thanks for the info guys I'm going to try to figure it out tonight after I get of work.
97catintenn
Jan 7, 2010 11:33 PM
Dufrain
Feb 22, 2008 09:29 AM
Magnum Fatboy
Jul 22, 2006 08:53 AM
Magnum Fatboy
Jul 21, 2006 09:22 PM
chad4589
May 29, 2005 09:07 PM
