transfer case seal
transfer case seal
i discovered today that my truck was dripping some fluid from what seems to be transfer case, where the yolk attaches to the front driveshaft. anyone have any advice or tips on replacing this part? how hard is it to actually replace, the part is only $13 so im hopeing it doesnt take a year and a day to replace as ive never done one before. TIA
mike
mike
hi
remove driveshaft
tap out old seal with scredriver
install new seal with something that fits over seal and contacts metal seal edge , pipe metal or plastic or what ever you have .
lube seal with trany fluid
reinstall driveline
take you bout 20 min total
remove driveshaft
reinstall driveline
Little harder than that, you have to remove the yoke since it is to the front driveshaft.
Still shouldn't be more than an hour.
You may want to have a speedi sleeve on hand just in case there is a groove worn on the yoke.
thanks for the input folks... the new seal is going in tomarrow. i know it sounds simple but it seems like whenever i do stuff that seems simple... its always worse than it should be... just figured i would check stuff out before i got my money maker all torn apart if you know what i mean. thanks again
DEC
Sep 29, 2003 09:47 AM
