transfer case not going in to gear
Old Oct 17, 2009 | 07:13 PM
bigrigger's Avatar
Unhappy transfer case not going in to gear
hi had the truck in the garage today changeing the front rotor and tie rod and happened to have it in 4lo while i was putting the wheel bearing back together i spun the wheel and noticed the front drive shaft turn accompanied with a grinding noise from the transfer case truck was in park and front drive shaft shouldn't have turned? is this a big problem or could it be shift rod adjustment issue thanks for any help or ideas
crawled under the truck this mornin to take a look and found the front driveshaft had striped the spline in the slip yoke
wyododge
Aug 18, 2011 07:48 AM
Mannie
Jan 1, 2007 09:48 PM
Toby
Oct 25, 2005 10:47 PM
vrj
Oct 20, 2005 05:47 PM
