Trans Temp and fuel pressure
Old Jun 9, 2005 | 11:58 AM
TxDiesel007's Avatar
Guys
just curious,
is a trans temp gauge really nessesary on a manual tranny? I want to get a triple pod a pillar gauge holder and want the boost, pyro and trans temp?
I have also read that Fuel pressure gauges arent nessesary on a 12V? can someone please clarify this?
Tx
Old Jun 9, 2005 | 01:08 PM
phox_mulder's Avatar
You really don't need either.
12 valve lift pumps don't have anywhere near the failure rate of the 24 valve ones.
phox
Old Jun 9, 2005 | 01:41 PM
CTD NUT's Avatar
There is no point in measuring the 5spd temp either......the critcal temp to measure is the temp between the meshing gears......measuring the sump temp is a very poor and inaccurate indicator of the mesh temps and will not indicate if you have reached a critical oil temp or not.
Old Jun 9, 2005 | 06:05 PM
Dual pod it is then
Thank you fellas!!!
Tx
genros
Oct 19, 2006 04:25 PM
Cumminsdude
15
Dec 28, 2003 01:16 PM
live wire
Jul 21, 2003 07:26 AM
