tranny line
Old Oct 27, 2004 | 09:42 PM
4doogie's Avatar
tranny line
How hard do you guys think replacing the tranny return line would be? A hole formed when the tranny line droped on to the cross member and rubbed I put a patch on it but still need to fix it, so should I have someone do it for me ( tranny shop ) or do it myself? when or if I go to do it what am I looking at? I know it needs to fit over the crossmember and it looks tight through there. Also what conects the ends? bolts? thanx for any help
Old Oct 28, 2004 | 01:15 PM
RCW's Avatar
RCW
The lines are really easy to replace, and most guys use the hose made for transmission coolers and clamps, and then just cut out the bad sections with a tubing cutter. Just be sure to blow out the line to get any metal particles out before you reassemble.
The hose makes it a snap to reinstall over and around the frame components.
The cooler lines connect with threaded ends.
Old Oct 29, 2004 | 12:02 AM
4doogie's Avatar
I already have the new tranny line, so I might as well replace it or have it replaced. from what you said it sounds easy so I think I'll do it when I have the time.
Hey do I need to drain the tranny fluid first or just take the line off?
Old Oct 29, 2004 | 07:32 AM
Eskimo's Avatar
When we cut into my hot line for a temp sender (did the $10 brass T), it self-drained... right down my arms, up my shirt, and pooled around my shoulders...
Old Oct 30, 2004 | 12:04 AM
4doogie's Avatar
oops I'll make a note of that
jimnod22
Aug 26, 2012 02:32 PM
Black Dog
Dec 3, 2009 08:18 PM
RoadDiesel
Jun 16, 2007 09:24 PM
Begle1
19
Aug 25, 2006 11:31 PM
