Tranny leaking a bit
Old Jan 29, 2008 | 08:50 PM
funcruise's Avatar
I have a 94 ctd with a DTT auto tranny and I noticed the other day there was a bit of red fluid in the snow where it was parked. Crawled under to have a look and pretty sure its coming from around where the gear selector shaft goes into the case. Anybody know if there is a seal, an o ring or whats in there. How hard is it to fix or would it be better to take it to a tranny shop and let them do it. They have a hoist and heat, I dont....
Old Jan 30, 2008 | 09:44 PM
dozer12216's Avatar
Actually there are two seals associated with gear selector shaft. one fits into the case and shift lever is sealed on outside. To replace. Take levers off and us a bent screw driver blaed to pry out seal. Install with a socket and c-clamp. Don't let shaft fall down.
The other is smaller and fits below the throttle shaft. Take E clip off smaller shaft. Remove washer and pry out seal. Don't let shaft fall down.
The NS switch just rearward also leaks occasionally. The KD band adjustment locknut needs a few drops of RTV to seal against.
lilsuzuki4x4
Sep 1, 2011 01:50 AM
1985cucv
Jun 5, 2010 02:35 PM
Common
Jun 9, 2008 12:16 PM
SMOKIN-U
Apr 27, 2008 02:26 PM
