TPS Threads Fun (20 pages worth!)
Old Feb 13, 2006 | 03:07 PM
billv45's Avatar
OK, I've been having so much fun reading all the TPS threads telling me how to clean my TPS here in this form in order to correct my shifting woes. I just called Advanced Auto (B'Ham AL) and they quoted me $33 for a new one. Am I missing something or are all the threads I read old and NOW no one cleans TPS's anymore since cheap new ones are available?
Old Feb 13, 2006 | 03:16 PM
JKM's Avatar
JKM
I think something fishy is going on , Go make sure that is the right TPS , IIRC they are 200+$ from the dealer , which is the only place i know to get them.
Are you sure they didn't look up a gasser?
Old Feb 13, 2006 | 03:21 PM
billv45's Avatar
They asked if it was a diesel and I said yes. I've got the pics from all the DIY TPS Cleaning instructions so I'll take them with me and at least make sure it looks similar.
Just called Advance's main store and they are showing two different TPS for a 12V Cummins (1996) one is $33 and the other $150 and they don't look alike and of course they don't have the $150 in stock. I'm going to go down there and take a look at it. Is it possible that someone has built a better (and cheaper) mouse trap?
Old Feb 13, 2006 | 03:45 PM
kandgo's Avatar
I would like to see one for $33, let us know. Look up member pappyman and he has photos in his gallery of one torn apart, they are easy to clean with two holes one on top and one on the bottome, with the dielectric cleaner and then seal back up. or take all the way apart and regrease with some dielectric greas.Goodluck,Rick
Old Feb 13, 2006 | 05:11 PM
Sidewinder's Avatar
I had the same thing happen - not sure which parts store it was. I drove down (to pick up 20 of them ) but it was the wrong model. The correct one was over $200.00. I think there is a typo in some of parts software.
Old Feb 13, 2006 | 07:53 PM
northslope's Avatar
Might try a Standard Motor Products# TH175
Old Feb 13, 2006 | 08:52 PM
billv45's Avatar
Nope, wrong one
I went down to Advanced Auto and low and behold, it was not the one we need. The correct TPS is $157 and of course not in stock. Got a can of cleaner and will give cleaning it a shot.
Now O'Reilly Auto parts has a life time guarantee for $168. I guess it'll be the last one I pay for (for this truck and maybe the next...)
Old Feb 14, 2006 | 12:06 AM
12valve's Avatar
where are the clean instructions??
and a friend of mine bought a TPS for
$330.00 dls, here in mexico!!!!
where are they cheapest, to get them there in usa??
thx
Old Feb 14, 2006 | 07:22 AM
billv45's Avatar
https://www.dieseltruckresource.com/...t=tps+cleaning
Old Feb 14, 2006 | 11:03 AM
kandgo's Avatar
Read thru it and I might also add to take the wires out going from the TPS to the PCM out of the wire loom and run them in thier own protected loom. I have had to do this several times as they will pick up interference and cause same symptoms. Some will just rewire and loose the wires in the loom, but it is not that hard to take them out. Goodluck,,Rick
Old Feb 15, 2006 | 11:23 PM
Hammily's Avatar
Thumbs up It was not my TPS!
First post. My truck is a 1996 2500 club cab 4x4, Auto, Long box, 129k Stock . My transmission would shift from second straight into overdrive. So I went through most of the pages of the info on the TPS. First I verified the linkage measurement. It was right. So I checked the TPS voltage, which is supposed to be 1.0 volt (+or- .2 volts)at idle position. Mine was .2 volts at idle. I cleaned the TPS and elongated the holes it on so I could rotate it. I installed it and checked the voltage again, rotated it, and I still could not get significantly higher voltage. According to the service manual I needed to replace the TPS. I took it off and was staring at the engine and I noticed that the flat bar that comes off the throttle linkage and goes into the TPS had groves worn into it from the pointy ears on the TPS. This was on a Saturday night and nothing was open, so I started to look around. I found a 1/16" piece of steel that I cut to fit inside the hole on the TPS to make a shim. I carefully put the TPS back on and checked the voltage and adjusted it so it was a 1 volt. Took it for a test ride and lo and behold I have 3rd gear back. I have only put on a few hundred miles, but so far so good.
John
whosdunit
May 17, 2014 08:54 AM
red_neck1984
Feb 6, 2008 03:23 PM
DDysput
May 5, 2004 07:44 AM
Stamey
Sep 25, 2003 10:07 PM
Stamey
Apr 20, 2003 10:44 AM
