The TPS sucks!
Old Apr 27, 2004 | 10:30 AM
Denis's Avatar
Angry The TPS sucks!
I'm going to replace it. I'm tired of screwing around with the thing. I cleaned it, rewired it, adjusted it, repositioned it, all for nothing.
It will work for 2 weeks, then screw me over like it did this weekend. Try driving 300 miles on I-95 without overdrive and not being able to make 65mpg comfortably.
The local Cummins shop doesn't have a part number for it because they say that Cummins shipped the engines to Dodge without them because they didn't know which engines would be auto or manual. However, I don't really want to pay the Dodge Dealer $250 for it.
Anyone found any other, less expensive places to get them?
I'm irritated, in case you couldn't tell.
Old Apr 27, 2004 | 12:00 PM
INJECTOR JACK's Avatar
Tps
Try another Cummins dealer.
Old Apr 27, 2004 | 12:01 PM
kandgo's Avatar
They can be found at NAPA auto parts stores,for alot less than dodge,Goodluck,Rick
Old Apr 27, 2004 | 12:08 PM
kandgo's Avatar
You might want to go ahead and wire you a switch that will lock up the torque converter for future problems, it is a hassle to be away from home and the tps start acting up, that is the only reason I wired one up, is to have it there in situations as you were in. Also if you do not have a manual do a search here on adjusting the tps when you install the new one as it will have to be adjusted. Goodluck,,Rick
whosdunit
May 17, 2014 08:54 AM
hvanflee
Feb 6, 2003 05:34 PM
tlampman
Dec 28, 2002 03:39 PM
Dieselbuilder
Dec 9, 2002 02:24 PM
gitchesum
Nov 6, 2002 10:30 PM
