Tps
Old Oct 21, 2008 | 07:44 PM
Mr. Jimmy's Avatar
Tps
A friend of mine just bought a 95 CTD and the truck is kicking in and out of OD ocassionally. I suspect the TPS is acting up. Where is the best place to buy and what is the price?
Old Oct 21, 2008 | 08:07 PM
jknowles4's Avatar
Try adjusting it first. Look up TPS adjustment. I have been researching this also. Lots of info. If you buy new then it is about $200 +/-
Old Oct 21, 2008 | 09:35 PM
ratsun's Avatar
Another possibility is noise?
Do search on ground isolators there is lots of info on them and its a common problem causing lock-up issues
Old Oct 22, 2008 | 09:39 AM
cumminsdriver635's Avatar
Do a search for putting a POT(potentiometer) in place of the TPS. Costs abut $4 and will fix the problem for good. There is a good thread with pictures in the 1st gen forum you can check out.
Eric
Old Oct 22, 2008 | 06:25 PM
infidel's Avatar
Last time I bought a TPS it was $149 from Napa.
Old Oct 23, 2008 | 08:23 AM
rconkin's Avatar
Eric
I found the thread in 1st gen and read it. Has anybody done this to a 2nd gen, particularly a 97? Does the TPS control anything else on a 97 that would not allow this to be done?
Old Oct 23, 2008 | 08:37 AM
OutlawStorm's Avatar
I have done the mod on my 96 truck, been over 2 years now and working great. When i did mine my TPS was basically dead . Also with the POT you can adjust the voltage and have OD lockup later,, mine would usually lock up under light throttle at about 45-48, now mine locks up at 55.
Old Oct 23, 2008 | 10:36 AM
MikeR's Avatar
When I bought my '95 back in 2001, the TPS would lock/unlock like crazy. I thought for sure I'd have to get a new sensor. I put in the noise filter kit from DTT and have never had the issue come back.
whosdunit
May 17, 2014 08:54 AM
Paradise Racing
Mar 18, 2003 06:26 PM
hvanflee
Mar 13, 2003 03:11 PM
feets
Jan 1, 2003 11:04 PM
