Timing tools
Timing tools
i'm new around here so if this is posted in the wrong place please let me know
I was wondering if any one had the specs on the 6842 Dial Indicator Adapter such as the thread dia and pitch.(for the p7100 bosh pump)
i have a few adapters lying around and was thinking one might work without having to spend the $$$
by the way if anyone has found a deal on the whole kit or just the delivery valve socket i sure would like to hear.
I think you can take an old oil drain plug drill a hole in it vertically for the dial indicator and then one horizontally for a set screw to hold the dial indicator in and you have your adapter. Or just measure your oil plug and see if you have one that matches.
GR40RCapri
Jun 25, 2006 12:53 AM
