Timing kit by Snap-on
Old Dec 24, 2005 | 12:58 PM
torquefan's Avatar
Originally Posted by JohnCA58
another thought is always use CONTACT CLEANER on the pump gear cleaning... do not use brake cleaner. contact cleaner will not leave a film on the parts had an apprentice lose a pump timing on the dyno last week , first question is what did you use for cleaning the gear..... uhhuh brake clean. so then he went and clean it out right and forgot to pull the pin out of the pump and engine and bent one and broke the other, sometime you just cant win.
John, are you referring to electrical contact cleaner? I've always used brake clean, and yes, I've had several slip while torquing the nut. I'd sure give this a try if you say it works better.
Thanks, Dave
Old Dec 24, 2005 | 01:11 PM
Stamey's Avatar
Originally Posted by 12valve
doesnt the piston kinda stay up for a while? until it goes down again?????
yesterday we set the pump, both timing pins set at tdc. but it wont rev up and it shutters horrible and lots of white smoke!!! could the timing pin be so off???
thx
You must have oopsed on the timing adjustment procedure. Your timing is severely retarded, with those symptoms.
Chris
Old Dec 24, 2005 | 01:20 PM
infidel's Avatar
Yes it does. Take the amount of rotation while the piston is at the upper stroke and divide it in half.
I've heard of timing pins being off as far as 5°.
I always use electronic cleaner since it doesn't leave residues like brake cleaner does.
franman
Nov 18, 2012 10:20 PM
jimjawz
Jun 15, 2004 01:33 PM
AZGEARPRO
Mar 16, 2004 06:59 AM
Donnie's Diesel
Jan 20, 2004 04:00 PM
KatDiesel
Jun 7, 2003 10:47 AM
