timing / idle help
Old Aug 12, 2009 | 02:25 PM
smokeyram's Avatar
timing / idle help
ok, long story short, i put in my 3GSk a while back, not paying nearly enough attention, made a mess of things and am now tired of 2 foot driving.
I need to get this either cleared up myself or finally into a pump shop and get it taken care of.
Here is what its doing- I put in the 3GSK, thought i counted clicks, got it all together, seemed to rev much higher, much easier. the downside, wasnt idling at all. I messed with 1 click out, one in, 2 clicks, spent the better part of a day messing with various settings and idle stop adjustments.
If i get it to idle in park, it will die in gear. if i get it to a point where it idles in gear, when i go into N or P it free revs way to high.
I need to find that happy medium where it idles and stays at that idle in gear.
For all i know there is a kickdown that is not working when the trans is put into a drive gear?
so, my questions are these
- Is there a kickdown that may not be functioning when i select a gear?
- should i do my timing, or have it done prior or after setting idle, i have a suspicion it has slipped
thanks
Old Aug 12, 2009 | 09:05 PM
infidel's Avatar
I think you should remove the GSK and start over paying more attention.
Sounds like you missed a shim or measurement.
Try these instructions, they're the best> http://www.pacbrake.com/PDF/L5658.PDF
Old Aug 13, 2009 | 07:30 AM
smokeyram's Avatar
thanks, i just might have to start over.
Should i not worry about the timing and get the idle set first?
Old Aug 13, 2009 | 09:31 AM
infidel's Avatar
That's what I would do since you admit you might not been paying full attention.
Old Aug 18, 2009 | 08:11 AM
smokeyram's Avatar
i agree, my only concern is that while attempting to get it to idle right i monkeyed with so many click settings and idle arm adjustments, that ill never be able to find the baseline again.
GR40RCapri
Jul 24, 2006 11:47 PM
GR40RCapri
Jun 25, 2006 12:53 AM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
redhornet
May 28, 2004 06:06 PM
