ticking sound from my 12V
Old Nov 16, 2006 | 03:49 PM
megajoltman's Avatar
ticking sound at idle coming from front left hand side of the engine. Just noticed it this week, is this normal ?
Old Nov 16, 2006 | 03:54 PM
schaef_12's Avatar
If the ticking sound is more audible on the Driver's side, in between the cab box, i think this is normal. Mine does it, My dad's does, and all the people i know who have 12v's do it. I don't think it is anything to worry about.
Old Nov 16, 2006 | 03:56 PM
It seems to be coming just above the left drivers side tire towards the front
Old Nov 16, 2006 | 04:52 PM
TIMMY22's Avatar
from what i've heard...
1. overflow valve
2. lift pump
Old Nov 16, 2006 | 05:20 PM
Forrest Nearing's Avatar
lift pump... the noise transfers down the hard steel fuel line to the tank also
Old Nov 16, 2006 | 06:27 PM
Thing is it doesn't happen all the time would the lift pump do this off and on ?
Old Nov 16, 2006 | 07:59 PM
TxDiesel007's Avatar
First suspect in my case
Lift pump,
its usually a sign that its possibly goin out.. or the overflow valve has pooped out.. If your truck is over 75K on the original, its cheap insurance... just change it out. Id suggest changing out the overflow valve, its cheaper and easier... Plus heck, ive done both, my valve and LP and it still ticks every so often, it comes and goes..
Rick
Old Nov 16, 2006 | 08:01 PM
kronikpain's Avatar
Could be the starter contacts going bad...That just happened to me.
Old Nov 16, 2006 | 08:25 PM
dalee's Avatar
My 2 Cents
mine had a ticking noise like you say and it was a fuel pump.
Old Nov 17, 2006 | 09:48 AM
Just did them a few months ago
Old Nov 17, 2006 | 09:56 AM
97ramctd's Avatar
Mine= ticking was drivin me nuts did do it all the time changed overflow valve didn't fix it, changed lift pump still no fix, changed fuel filter fixed kinda wierd but it happened.
Old Nov 17, 2006 | 10:29 AM
Well I need to do my fuel filter, new one been sitting in my glovebox for over a month if only this heavy rain would stop. I'm kind of worried about priming the system after I change it though
Old Nov 17, 2006 | 10:34 AM
Common's Avatar
Do the fuel filter...
It will go away, mine did the EXACT same thing, like lighting a gas stove kind of ticking...
Old Nov 17, 2006 | 01:31 PM
jetsnow's Avatar
where is the fuel filter and how easy is it to change it? I know i need to change mine. Any help would be appreciated.
Thanks, Sean
Old Nov 17, 2006 | 02:55 PM
Txwelder's Avatar
I have had the same ticking episodes in the past as well. If the ticking goes away with RPM then it is the overflow valve. If the ticking increases as RPM increases it is the sping in your lift pump wearing out and the rod inside the pump is slaping your cam lobe, wearing out your cam. Replace the overflow first and if it doesnt fix it but the ticking still goes away with RPM, then it is the haunted 12 valve tick, they all have it at some point.
