throttle let go
Old Feb 1, 2012 | 09:03 PM
srv8800's Avatar
throttle let go
is there a common part that let's go in the throttle assembly?
I'm currently idling down the hwy in 5th gear trying to get home, doing a little over 20mph bc something let go b/t the pedal and injector pump. the cable still moves the arm on the pump but it's dark and thats all I could see. need to fix this to get to work in the AM. thanks
Old Feb 1, 2012 | 09:54 PM
cj360trider's Avatar
sounds like something fell off inside the pump. itll prolly need to come off and be serviced by a pump shop
Old Feb 2, 2012 | 03:47 PM
Tate's Avatar
It could be the long linkage rod that came off. Its easy to speculate on our end, you'll need a light to see it, should be pretty obvious if its an external linkage problem.
JamesOneill
Jan 27, 2014 03:24 AM
madhat
Nov 28, 2009 04:31 PM
bkoz
17
Oct 18, 2009 09:32 PM
Hoss
Dec 10, 2005 02:30 AM
