TEMP Guage UP then falls down
Old Apr 2, 2004 | 12:35 PM
Big Ben's Avatar
Just a quick question on my 1997 12v. The temp guage never seems to reach a constant temp and stay there. Once the engine gets warm and the temp get to @170-175 it will then drop rather quickly back to @150 and slowley creep back up to the 170 mark then fall again. once the truck is warm it cycles between 140-170 with in about 1min. is this normal?
Thanks
Ben
Old Apr 2, 2004 | 12:54 PM
P.O.R.'s Avatar
this is normal,these trucks have a large cooling system and when not being worked this is what happens,i use a winter front to help keep the truck warm and a constant temp when not being worked,then adjust according to load and temp......hope this helps......
Old Apr 12, 2004 | 10:21 PM
Cummins66's Avatar
Does the truck have the original T-stat. If not, this is a really bad problem with most replacements. There is one out there from Cummins that can correct this, but I don't remember the part #. Might be able to get it from local Dodge dealer, or maybe someone else knows it.
Old Apr 12, 2004 | 11:19 PM
infidel's Avatar
I went with the "improved" stat, it kept the temp steady but too low, went back to the old one. A lot of it has to do with the location of the coolant sensor. If you have a oil temp gauge or even a pyro you will see that their temps don't swing with the coolant temp, the block temp is remaining constant and there is really no reason for concern.
Diesel-Dan
20
Sep 22, 2019 09:34 PM
DryCreek
Jun 18, 2012 05:20 PM
12valve
Nov 17, 2006 09:47 PM
12valve
Dec 25, 2005 01:29 AM
