TCC lockup/unlock wiring and warnings
Old Mar 10, 2004 | 07:33 PM
vtailflyer's Avatar
Post TCC lockup/unlock wiring and warnings
Hi All,
Any thoughts on this setup? a little much (my wife asks if it is really worth it )
I am ding the last finishing touches and it seems to work good with the truck on jacks simulating it
Cheers
Old Mar 10, 2004 | 09:50 PM
Crimedog's Avatar
That's a pretty slick design!!! I wish I could dream up those wirings
Old Mar 10, 2004 | 10:07 PM
Cummins66's Avatar
That looks pretty awesome! I'm certainly no electrician, but I might have to give that a try on my truck (with some help from someone who knows more about electricity). Thanks for the diagram!
Old Mar 11, 2004 | 09:47 AM
infidel's Avatar
Thank you much, I was considering a similar setup, you saved me quite a bit of thinking. I had especially wanted a system that would indicate when the TC was locked no matter which mode the lockup switch was in, this foots the bill.
Any specs on the buzzer?
Do you mind if I share your diagram on other websites?
Old Mar 11, 2004 | 11:09 AM
Mcmopar's Avatar
Pretty impressive, Mine has a green led for "normal" stock mode and a red light for "locked" mode, I included an unlocked mode if needed. No buzzer though-nice touch. My design only uses two leds and on DPDT switch from Radio shack, total cost 10.00
Old Mar 11, 2004 | 11:12 AM
vtailflyer's Avatar
Geez, I re-read my post, I got to check my spelling before I post
The Buzzer is from a local electronincs place, pick your noise level to suit. I think mine is 2.4 KHZ??
I considered putting an electric prod under the passenger seat as an option, that would get my attention for sure
Infidel, I have got my fair share of info here, so feel free to share, Its always nice to be able to give back.
Cheers
Old Mar 11, 2004 | 11:59 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Nice! if you have no complaints, I would like to add that to our Tech Facts section?
Old Mar 11, 2004 | 02:19 PM
vtailflyer's Avatar
Hi Top,
No problem, feel free to add.
Hope it helps...
Old Mar 11, 2004 | 07:09 PM
Admin Team Leader
Thanks! Great Job!
Old Mar 11, 2004 | 07:57 PM
vtailflyer's Avatar
OK, tried it all out today and worked great.
If you manually lock the TC witht he switch:
If you are in 3rd or OD with TCC locked and "touch" the brakes the horn comes on momentarily, TCC stays locked. In drive below about 40KM/HR the horn is "on" telling you something is wrong...Unlock the switch!!! same in OD but speed is about 70 KM/HR.
One Burp though... The throttle has to be pressed to about 1050rpm to move the TPS sensor enuf to make the PCM believe there is a little throttle and not to unlock the TCC... if you don't the horn is on all the time the throttle is released, however the TCC is still locked.
I will have to look into this and see if I can do alittle something, look forward to revision 1 to the drawing.
It may take me a week as I will be outatown
Cheers
Old Apr 2, 2004 | 07:09 PM
vtailflyer's Avatar
I have been driving the truck in this config and pulling the fiver with it and am very pleased with the results. I did not put in the RED light, however the buzzer I put in is more that enuf to let you know that your switch is in the locked position (and TCC locked) and the truck is saying UNLOCK
Cheers
Old Apr 2, 2004 | 10:54 PM
lifer's Avatar
I want to do this to my truck. Does anyone have numbers or info on the voltge sensing relays that are being used? Its been a long time since I did much with schematics,is that a diode on the left in the middle of the wire going to the pcm?
dperf
15
Sep 14, 2006 05:00 PM
John Rodriguez
Sep 26, 2005 07:34 PM
firesine
Jun 9, 2005 12:35 AM
slayerfish
Jan 7, 2003 08:08 PM
