TC lock up???
Old May 13, 2008 | 03:39 PM
jknowles4's Avatar
TC lock up???
This may sound stupid but how can you tell if your torque converter is locking up? I don't think mine does.
Old May 13, 2008 | 03:57 PM
xzaq103's Avatar
At about 45mph does the truck jolt a little and then feel like it has more power?
Old May 13, 2008 | 07:31 PM
jknowles4's Avatar
I don't think so. How well can you feel it? Is it like it is going into another gear or just a slight movement.
Old May 13, 2008 | 08:07 PM
GearHd6's Avatar
If you've got a stock converter its like its going into another gear, and the RPM's will drop about 300-400. If you've got 3.54 rear gears the converter will lock at 30-32 mph in drive and 48-50 mph in OD.
Old May 13, 2008 | 08:33 PM
gorms's Avatar
A good test is when it would be locked in, like 35-40 mph with o/d off on steady throttle, tap the brakes a bit while keeping the steady throttle. If you hear the motor (or see the tach) go up a few hundred RPM, it's working.
Old May 15, 2008 | 06:30 PM
kevellis32's Avatar
If your asking, I bet your converter is slipping a bit.
Old May 15, 2008 | 06:37 PM
turboman1's Avatar
take it up to like 55 mph then push the gas down about half way. If the rpms do not rev up say 600 then it is locked. In fact they should barely go up but rise gradually as speed increases. You will also hear the engine lugging somewhat or i guess i could say the engine is actually doing some work.
Hope this helps
Adam
Old May 16, 2008 | 11:50 AM
Troutstrannysvc's Avatar
These guys all gave you good advice.
When your TC engages in lockup you will be able to watch your RPMS and your MPH climb at the same rate. The needles should be equally climbing.
Is your check engine light on, what year truck?
And once in lockup if you tap the brake it will go out of lockup.
-Jared
JKM
Sep 23, 2007 11:38 AM
xp8103
Jun 2, 2006 07:00 AM
mr T
21
Jun 1, 2005 08:48 AM
Nuttymopar
Sep 2, 2004 07:39 AM
damon_achey
Jun 7, 2004 03:33 PM
