swapping to auto
Old Aug 12, 2006 | 07:52 PM
tinman1911's Avatar
swapping to auto
ok guys im gonna pull my 5sp out and put auto in i already have the 47/rh
and flywheel . I know im gonna have to change crossmember have my driveshaft changed tranny cooler lines linkage etc . So is there anything im missing will i need a tps or just put manual valvebobdy in it?
Old Aug 12, 2006 | 09:56 PM
Forrest Nearing's Avatar
I've got a fully programable stand-alone ATS valve body that would help you out a lot
Old Aug 12, 2006 | 10:08 PM
~Angry Tractor~'s Avatar
Sooooooo I guess I could swing by and pick up that 5 speed and hardware for it, seeins how you wont be needin it anymore
Old Aug 14, 2006 | 11:43 AM
risner's Avatar
all you should need is the bracket that goes on top of the rubber mount for the crossmember. it bolts to the rubber mount and the transmission. are you going to run the heat exchanger that is normally mounted under the turbo on the auto trucks? i have that and the lines. what about the steering column? drive shaft. and yes TPS.
Old Aug 15, 2006 | 12:20 PM
OFFDUTYEXPEDITOR's Avatar
A tow truck on stand-by might also be advisable. After all the posts on these lousy automatics, why would you want to convert over to one???
Old Aug 15, 2006 | 09:29 PM
tinman1911's Avatar
im not gonna run a stock tranny cooler going with aftermarket one
im gonna have my driveshaft dont at precision driveline
as for the steering colum im not gonna mess with that ill put an aftermarket shifter in the floor
my 5sp will be for sale after swap ill post it on here
forrest if i had the ats valve body i could get away without haveing a tps right?
Old Aug 17, 2006 | 03:14 AM
cumminsdriver635's Avatar
Because for about $3200 you can have one with a 100k warranty no matter the HP(except the shafts). Find a manual/clutch with a 100k warranty for that cheap. Also; my converter has a lifetime unlimited power warranty. Think you can find a clutch with that warranty for $1200?
Eric
O791challenger
Jul 12, 2008 12:53 PM
West Coast
Apr 18, 2008 11:25 AM
je27
Feb 1, 2008 10:53 AM
Mike Holmen
23
Jun 12, 2006 03:52 PM
BigBlue
19
Aug 10, 2005 01:38 AM
