swaping out the dana 70
Old May 8, 2007 | 03:24 PM
NorKal12valve's Avatar
I have a 1997 12v with almost 300K on it. The limited slip carrier is wiped out, everytime i engage/disengage the the trans i get a really bad clunk out of the rearend, also when driving and letting off the throttle quickly it clunks really bad. I took the cover off, and it looks to me like the play is coming from the pin through the carrier. So looking ta the price of carriers, like $700 for a replacement, plus install kit, and time. So im thinking of picking up a 14 bolt or dana 60 complete assembly. Can be had for about $200 for a real nice complete one. One thing, my dana 70 has abs sensor on it. what happends if i swap in an older axle without this and leave it unpluged? Any help would be great. Thanks, Kodi
Old May 8, 2007 | 10:53 PM
does anyone know about the abs stuff?
Old May 9, 2007 | 12:17 AM
Crimedog's Avatar
You might want to make sure the spring perches are the same width if you swap in a 14 bolt or a 60. I think I would shy away from a 60, as I don't know if it would hold up to the torque in the long run. You might want to make sure that it is not your rear u joint causing the clunk, or the ring and pinion. There are alos always limited slips to be had on ebay for less than $150 or so, that it another option.
As to your original question, if you unplug the ABS wire I think you will just lose your ABS function and set a light on the dash. Your speedo sensor is in the transfer case so you will be fine in that department.
Old May 9, 2007 | 02:16 AM
i will modify the 14 bolt or 60 and put the perches where they need to be, along with the rest of the stock brackets i will cut off the old axle andre-install on the new one, my only delima is the abs sensor, so i guess i will unplug it and run it nowand see what happends. I just didnt wasnt it to locl up or somthing stupid. Thanks, Kodi
Old May 9, 2007 | 08:08 AM
97' CTD's Avatar
I think the sensor in the pig is your speedo. Unplug it and see if you speedometer works???<
theonlyz
25
May 15, 2009 06:34 PM
Mopar72
Mar 25, 2008 11:25 PM
gunracer1
Dec 18, 2006 08:18 AM
DODGE 92
Sep 4, 2006 07:27 PM
boughtadodge
Dec 6, 2002 01:11 PM
