Stiff clutch pedal.... Normal... or not?????
Old May 12, 2009 | 09:35 PM
GCSS's Avatar
I have a 1998 12V 2wd quad cab 3/4 ton and I prefer to drive my 1992 4wd truck (also a cummins) because the clutch pedal kills my ankle.
The previous owner said a new clutch was installed,but can a bad clutch slave or something cause the pedal to be stiffer than normal?
They made no mention of any HP clutch.
I am looking for the possibilities...
Thanks..
DD
Old May 12, 2009 | 11:06 PM
HotRodTodd's Avatar
The OEM clutch is a diaphram type with many small levers spreading the pressure over a larger area giving you a softer pedal.
The replacement clutch they installed is more than likely a lever type HD clutch that only has 3 levers counteracting stiffer springs which gives you a stiffer pedal.
You may be able to find a slave cylinder with a larger bore size making the pedal easier to push.
Old May 12, 2009 | 11:17 PM
GCSS's Avatar
know who sells the larger bore slave cylinder?
Old May 12, 2009 | 11:21 PM
1-5-3-6-2-4's Avatar
South bend clutch sells a HD hydraulics upgrade. less than $200 IIRC.
Old May 12, 2009 | 11:25 PM
GCSS's Avatar
I'll give them a call in the morning
Thanks!
Old May 13, 2009 | 06:13 PM
seahawkdodge's Avatar
That's cheaper than the OEM replacement from the dealer...
Old May 13, 2009 | 07:53 PM
GCSS's Avatar
I called south bend this morning ...just a bit over $300 and no better than a stock unit pressure wise.
I am going to have to tear it apart to find out what I have for a clutch...
Old May 13, 2009 | 09:50 PM
cmac's Avatar
is it getting worse or was it like that since you had it? i noticed when i put in a new clutch the pedal was alot easier to push in and slowly gets stiffer as it gets worn out. just my observation.
Old May 13, 2009 | 10:16 PM
was not sure on the price. thats more than I though.
then whats the hydraulics upgrade than folks usually put in after upgrading to a heavy pound dual disk? I'm sure it came from SBC>
when I DD my '98.5 from the stock clutch. pedal pressure went waaay up. I never upgraded the hydraulics from stock though I understood the option was there.
Old May 14, 2009 | 08:00 AM
GCSS's Avatar
It was always stiff.
The lady whom I purchased it from told me her late husband (80 yrs old) had a new clutch put in.
The truck only has 112,000 miles on it. That's all I know about it
turfguy
Oct 27, 2009 08:40 AM
bcfreighttrain
Jun 7, 2008 02:55 AM
buffeagle
May 7, 2008 03:50 PM
fishermansteve
Feb 9, 2004 09:05 PM
