sparks from front balancer
Old Mar 4, 2011 | 04:57 PM
jughead's Avatar
i have a friend with 97 dually that has static electric sparks coming from the engine balancer. i know i read it somewhere. i did do a search came up with zero. anyone know of it or what causes it.
Old Mar 5, 2011 | 06:14 PM
G1625S's Avatar
Crank sensor set too close causing sparks? Beyond that, unless the crank runout is absurd and the damper is hitting the timing cover, I'm at a loss...
Old Mar 5, 2011 | 06:29 PM
jughead's Avatar
sparks
think i found the answer on another board. the thing is mounted in rubber and the rubber is rubbing the gear cover causing static electricity to build in the outside ring. will check it out later and report.
Old Mar 6, 2011 | 08:27 AM
toms73novass's Avatar
It is either that or your fan belt can be slipping causing the same static charge.
Shorts
Aug 18, 2011 10:29 PM
Racing_Joe66
Jun 14, 2011 10:40 AM
Bobcat698
Sep 23, 2005 09:06 AM
Lary Ellis (Top)
Site News
Aug 26, 2003 01:57 PM
