snap ring broke...
Old May 21, 2007 | 09:11 PM
cmac's Avatar
Question snap ring broke...
i went home to minnesota a couple weeks ago. while i was there a snap ring broke, it was on the tail shaft after it comes out of the transfer case right up against the last bearing. has anyone else had problems with this?? The previous owner of the truck is my uncle and it had did it to him once before too. i got lucky.... when it broke on him he bought two snap rings in case it did it again (mainly because it took 3-4 days to get it from the dealer) any insight on this would be great. it's an easy fix i just don't want it to happen on one of my road trips. thanks -Chris
Old May 21, 2007 | 09:40 PM
westexhunt's Avatar
Somewhat common.
I have had one truck that was bad, it would break the snap ring about every 15-20k miles. I was pretty quick at fixing it and sold the truck before I had the trans worked on by someone else.
Old May 21, 2007 | 11:00 PM
Box5's Avatar
theres a t-case saver that u can get to fix that problem. Most likely someone took the snap ring off once and didn't replace it, so it was alittle distorted.
Old May 21, 2007 | 11:17 PM
Clayten's Avatar
DTR's Toad Wrangler
Ya there is an up grade for that. I had a Ford diesel in my mirror, I was wanting to enter the highway. So the last time I looked I was boosting through 16 lbs, and boom. Probably over 20 when it broke. I took out everything including the chain.
Old May 21, 2007 | 11:24 PM
Box5's Avatar
yea, that snap ring is all that holds the entire guts of the t-case in alignment.
Old May 22, 2007 | 11:17 AM
vssman's Avatar
Yeah - you don't want to drive it if the ring is broken. It'll take out just about everything in the transfer case. Don't ask how I found out...
Old May 22, 2007 | 11:39 AM
Ram of Steel's Avatar
This is where I purchased my snap ring. I believe it is actually from a Ford T/case.
http://www.transfercases.com/
Old May 22, 2007 | 04:41 PM
Clayten's Avatar
DTR's Toad Wrangler
This is the part I put on min to keep the transfer case in one piece.
http://www.drivetrain.com/gillies/Tcasesaver.html
Old May 22, 2007 | 04:55 PM
Dshiftff's Avatar
thanks for posting that, I think Ill order one. with vssman posting above, thats 2 people from my area alone that have had this problem.
oops on edit: It appears this product does not fit a 241HD which is what I have.. The guy from drivetrain specialists is trying to find me a aircraft grade snap ring.
Old May 22, 2007 | 05:32 PM
Box5's Avatar
Just get a new one from ur dodge dealer. They should have one in stock, or be able to have one the next day, and its only $4.
Old May 22, 2007 | 05:42 PM
Clayten's Avatar
DTR's Toad Wrangler
I have heard that the Ford snap ring for their transfer case works and is a better product.
Old May 22, 2007 | 09:38 PM
kawi600's Avatar
Ahh crud, I have the 241HD also I think.. Theres some reason this kind of assembly wont fit on the heavy duty version?
Old May 23, 2007 | 01:36 PM
Dshiftff's Avatar
according to the guy from drivetrain specailties, the output shaft is bigger, thus wont fit.
Old May 23, 2007 | 05:59 PM
cmac's Avatar
thanks for the help. i'm most likely going to get that t-case saver. it loks like an easy solution to this stupid problem. not that its hard to fix... just don't want it to happen going down the road. thanks again!!
Old May 23, 2007 | 09:21 PM
Dshiftff's Avatar
does anyone know if there are any symptoms that lead up to this? sounds, vibes, etc?
