smelling coolant
Old Jun 18, 2007 | 10:25 AM
smokeyram's Avatar
smelling coolant
AC works fine, truck doesnt over heat, heat works fine.
When hot out, from time to time, I catch a whiff of anti freeze.
No oil in the radiator, no coolant in the oil.
Cant find a leak.
Where could the smell be?
Old Jun 18, 2007 | 10:45 AM
JD730's Avatar
Check up by the front of the head on the passenger side below the thermostat housing. I have 2 here that do the same thing from time to time, little whiff of coolant when hot every once in a while. Same spot on both of them, up under the thermostat where head meets the block.
Old Jun 19, 2007 | 02:11 PM
ccmckee's Avatar
Check the front corner #1 and the back corner #6 for a weep from the head gasket, these are two known spots for leakage. Also may want to get a mirror and check the big frost plug in the back of the head and the temp sender as well.
Old Jun 19, 2007 | 03:54 PM
atc250r's Avatar
Is the smell inside? It could be a leak from the heater core.
John
mx684
Feb 18, 2007 04:13 PM
anpconnors
Nov 7, 2006 11:38 AM
digbog
Aug 26, 2006 10:22 PM
skargo
15
Apr 28, 2006 02:24 PM
BamBam
13
Feb 25, 2003 12:59 PM
