Silencer Ring?
Old Jun 10, 2009 | 10:32 AM
ram 2500's Avatar
Silencer Ring?
What is a Silencer Ring?
Old Jun 10, 2009 | 10:59 AM
Kenny D's Avatar
its a small olmost cone shaped ring on the intake side of out turbos that mother mopar put there to quiet down the wistle. Allot of us have taken it out and love it. Its a 10 min thing to get it out.
Old Jun 10, 2009 | 11:00 AM
Lil Dog's Avatar
The Silencer ring is a thin metal deflector mounted on the inlet to the turbocharger. Its held in with a large snap ring. The silencer ring was made to reduce the audible turbo whistle that was bothering some owners. Removal of this ring is purely for noise control and has no affect on performance.
Old Jun 14, 2009 | 03:32 PM
shima's Avatar
I pulled out the lock ring and silencer ring, but was also understanding that the baffles from inside the intake duct needed to come out as well. They do not come out very easy compared to the silencer ring, but with a recip saw, I as able to get them out. This is what they looked like when I got done with them.
Does that sound and look right? It doesn't change the sound at idle or driving the way I do. (Like a grandpa) But when you get on it, it sounds good. My wife said it sounds like an airplane.
Old Jun 14, 2009 | 04:07 PM
Yellow Yota's Avatar
Where did those parts come from? How large are they? For what it's worth, it would be a lot more helpful if there was something in the picture that gave a size comparison. Such as a tape measure, a quarter, dollar bill, or anything that is a size that everyone will recognize.
Thanks!
Old Jun 14, 2009 | 09:24 PM
shima's Avatar
It came from here. Sorry, I noticed this was the 12 valve section after I posted. It may be different on your truck. Mine is a 2006, 24 valve.
Like I said, I don't know how similar it is.
Old Jun 15, 2009 | 10:29 AM
Lil Dog's Avatar
Way different.. Our hoses don't have any baffles in them.
Old Jun 15, 2009 | 12:09 PM
infidel's Avatar
The 3rd gen baffles you removed are there to straighten out airflow to the turbo. Improves turbo efficiency.
It is counterproductive to remove them.
Old Jun 15, 2009 | 12:26 PM
ram 2500's Avatar
Can some body give me some directions on how to remove the ring on a 24V
Old Jun 15, 2009 | 03:00 PM
shima's Avatar
Yep, Disconnect the connector on top of the air box. Remove the air intake duct in the picture above from the air box and turbo. On the turbo, you'll see a lock ring around the inside of the turbo air inlet. The lock ring comes out by CAREFULLY prying it out with a small straight slot screwdriver, hook pick, or awl. The silencer ring will fall out after you remove the lock ring. Make sure to wipe any debris or metal shavings out of the turbo inlet with a clean rag. Put the duct back on. Connect your connector on the airbox. You're done.
RonP
Feb 17, 2010 09:30 AM
RRC
May 13, 2007 11:45 PM
HaulinBut
May 12, 2006 03:06 PM
StrokeThis2500
Dec 31, 2005 05:19 PM
