silencer ring
Old Apr 29, 2007 | 01:45 PM
cmac's Avatar
silencer ring
i know it's probably a simple thing to do but can anyone tell me how to take out the silencer ring? thanks!
Old Apr 29, 2007 | 01:54 PM
Black Beast76's Avatar
Take your air intake off the turbo, get a flat head screwdriver and pry the clip up that holds the ring in place, could be stubborn to pry, but once you get it off just pull the ring out. Then your done. That simple.
Old Apr 29, 2007 | 02:07 PM
Dr. Evil's Avatar
Look here:
http://www.dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
About 1/4 the way down the page.
Old Apr 29, 2007 | 02:18 PM
skynyrd's Avatar
this is one of those " what are they? what do they really do? how do i get rid of them?" questions. lol
two straight screwdrivers one to pry up on the ring and one to pry outward with. pull the snap ring out then pull the ring out and put the intake tube back in.
Old Apr 29, 2007 | 02:51 PM
clutch1's Avatar
dont bother, leave it in.
Old Apr 30, 2007 | 05:18 PM
cmac's Avatar
thanks. that seems easy enough. now i guess i'll go see what it sounds like.
Old Apr 30, 2007 | 08:04 PM
cmac's Avatar
so is there a trick to doing this cause i'm not gettin it????
Old Apr 30, 2007 | 08:51 PM
Jeremy Cusick's Avatar
That snapring can be stubborn... might need to use an o-ring pick to get under the end of it and then slip the screwdriver in to pry it out. Or do what I did, and grit you teeth and keep at it. It'll come out eventually, with some persistance.
Old May 4, 2007 | 08:30 AM
cmac's Avatar
Thanks... I got it off and to be honest it sounds pretty good. I like it!!
RonP
Feb 17, 2010 09:30 AM
RRC
May 13, 2007 11:45 PM
HaulinBut
May 12, 2006 03:06 PM
StrokeThis2500
Dec 31, 2005 05:19 PM
