Silencer ring
Old Jan 14, 2007 | 08:17 PM
Monkey 456's Avatar
Silencer ring
Hay I just joined the form and I am liking what i see. What is the silencer ring and wear is so i can rip it out?
Old Jan 14, 2007 | 08:27 PM
displacedtexan's Avatar
It is a cone shaped ring in the turbo inlet, it is held in place with a snap ring. Pop the intake tube off, you can use a flat head screwdriver to start getting the snap ring lose, another one is handy when you are working it out, pop the snap ring out, pull the silencer ring out, reconnect the intake tube, and you are good to go.
FWIW- There are no power gains to removing it.
Old Jan 14, 2007 | 09:30 PM
Monkey 456's Avatar
I was just wondering why all most every body says they have taken thears out.
Old Jan 14, 2007 | 09:33 PM
TxDiesel007's Avatar
many people like the turbo whistle
which is the primary reason that they pull out the ring in the first place. If you want a bit more sound as well, go ahead and pull the little connection tube from the side of the airbox taht connects to the passenger side fender.. It will whistle just a tad more with that...
Rick
Old Jan 14, 2007 | 10:55 PM
I am one that took it out for the sound.
You can also fill the bottom part of the airbox with holes, slightly more air and noise.
Old Jan 21, 2007 | 01:26 PM
sickandtwisted's Avatar
After removal of the silencer ring is the snap ring supposed to be reinstalled? It's probally a stupid question but, I want to be sure before I go messing with it. You know?
Old Jan 21, 2007 | 01:49 PM
Need95-00CTD's Avatar
Don't need to reinstall it.
Old Jan 21, 2007 | 04:35 PM
Fueling around's Avatar
A performance reason to remove the ring is to open the MWE or map width enhancement slots in the compressor housing.
Personally, I couldn't take the high pitch whistle after removing the ring. I even discarded an aftermarket filter and went back to the stock box to quiet the intake noise.
Old Jan 21, 2007 | 05:41 PM
Monkey 456's Avatar
Well I think I will take mine out but I am not going to throw it out.
Old Jan 21, 2007 | 06:41 PM
Forgot to welcome you to DTR.
RonP
Feb 17, 2010 09:30 AM
RRC
May 13, 2007 11:45 PM
HaulinBut
May 12, 2006 03:06 PM
StrokeThis2500
Dec 31, 2005 05:19 PM
