Show and Go 12 valver
Old Aug 24, 2003 | 08:39 PM
gitchesum's Avatar
The twins are gonna look sweet on this one. The fuel lines and intake are coated as well.
This motor is being built by a friend of mine. We were planning on just installing a new head on the motor in his truck but found a horizontal crack in the #6 cylinder wall. Since he had a couple of motors laying around, he decided to build one from the ground up.
The pistons are coated with two different coating. The tops are coated in ceramic, with the skirts and main and rod bearings being coated with a dry film lube by Polymer Dynamics here in Houston.
With a set of Prince injectors, PDR cam, and twin turbos this thing's definately gonna have show and go.
Old Aug 24, 2003 | 08:42 PM
WHIFF's Avatar
Re:Show and Go 12 valver
Sweet! 8)
Old Aug 26, 2003 | 12:20 PM
Superduty12v's Avatar
Muted User
Any idea what this has ran him so far for the engine (not including twins, etc)? I have an engine sitting in my garage waiting for basically the same thing. As far as the coated pistons, rebuild, cam, studs, etc. I'd really appreciate a rough estimate so I can better plan.
Old Aug 26, 2003 | 01:36 PM
Dr. Evil's Avatar
Wanna trade for my 24V??? Lemme know ;D
Old Aug 27, 2003 | 08:17 PM
gitchesum's Avatar
The fastest the truck has run before is a 14.5 I think. That was with a 175 pump, #0 plate, 370 injectors and DTT tranny.
We're hoping to be in the 12's with the new motor and mods. ;D
We still don't have a total as far as cost, but I can get you some numbers in a few days SD12V.
The cam was bought through Chris Strickland at Relentless diesel, as was the big turbo.The coating were done by Polymer Dynamics in Houston. They do a lot of work for NASCAR engine builders. Give them a call and they should be able to tell you what you need. Just ask them about the motor Michael Watkins built and they should know what you're talking about.
Old Aug 27, 2003 | 11:03 PM
Dr. Evil's Avatar
That is wild.....good luck keeping tires on it.
Old Aug 29, 2003 | 12:44 PM
Muted User
Better tab that KDP before you paste the cover on.
Old Aug 29, 2003 | 05:10 PM
Holsteinman's Avatar
That looks awesome!
Old Aug 29, 2003 | 11:13 PM
TxDieselKid's Avatar
I like the injection lines the most I think! 8)
That or the speed ratchet I think!
CZ
May 24, 2005 05:45 PM
SjLingenfelter
Nov 12, 2004 10:23 PM
cumminsman02
Mar 30, 2004 04:36 PM
BigBlue
20
Feb 4, 2003 02:15 PM
bigbaddiesel
Jan 3, 2003 12:36 PM
