Should I Keep the 4.10's?
Old Dec 28, 2011 | 12:02 PM
flyingd's Avatar
I took a trip down the I-5 with my camper, about 3k, doing about 70mph and got 12.5 mpg on the fuel. This was from Klamath Falls OR to Visalia CA. I could have gotten better fuel mileage if I had dropped the speed to at least 65. I have the 4.10s and wonder if it would be worth the trouble of getting the 3.54's; if it would make a lot of difference. at 70 the tach is at between 23 and 2400 rpm. I will be towing a boat also, about 2500 lbs, just not this trip. Or would it be better to put one of those in-line overdrives in. That way I could keep the lower gearing for towing up and down the mountains.
I guess I could just go slower, but that is very hard; also takes longer to get someplace.
Any ideas would be appreciated
Old Dec 28, 2011 | 12:19 PM
BILTIT's Avatar
Either, or both! In the end the gear change will be slightly cheaper.
By the numbers the gear change alone would theoretically drop your cruise rpm by ~360rpm (fixed!) but with the auto it will most likely be realistically closer to 300rpm.
The GV OD unit will drop it ~4-600rpm with the 4.10s.
Both would see ~700rpm drop.
I am sure someone who is running either or both can give you actual numbers.
Old Dec 28, 2011 | 01:17 PM
jstone44720's Avatar
You might get 5% or 6% MPG difference. 1-2 MPG maybe? It would take a lot of miles to pay back unless you found somebody that wanted to swap axles.
@BILTIT - how are you getting 900 engine RPM drop at constant ground speed? For 265/75-16 tires and .76 OD transmission ratio, at 70 MPH I am getting 2000 RPM and 2300 RPM for 3.54 and 4:10 respectively. What did I do wrong?
Old Dec 28, 2011 | 02:05 PM
BILTIT's Avatar
I did it wrong, used just the ratio difference as a percent. You are correct, doing it properly i am getting ~360rpm difference for the gear change alone.
Also GV site shows OD as .69?
Old Dec 28, 2011 | 03:59 PM
.76 is what I think the OD is in my nv4500. Gear vendors may be better.
Old Dec 28, 2011 | 04:12 PM
BILTIT's Avatar
His truck is an auto so it will be a slightly different OD.
Old Dec 28, 2011 | 05:20 PM
flyingd's Avatar
Is the Gear Vender able to hold up to hauling the weight???
Old Dec 28, 2011 | 05:23 PM
BILTIT's Avatar
"GEAR VENDORS provides overdrive product to racing cars and trucks up to 2000hp and trucks towing heavy RV's up to 25,000lbs gcvw."
Old Dec 29, 2011 | 02:34 PM
flyingd's Avatar
I'll take that as a yes
Old Dec 29, 2011 | 07:23 PM
MikeR's Avatar
No don't do an OD unit, they're junk and don't hold up to diesels very long.
The place I worked at was contantly changing those things out, the torque just shreads them up. Old rigs with 3-speed trans okay..but diesels no.
Old Dec 30, 2011 | 11:13 AM
flyingd's Avatar
Wouldn't it be great if they made a two speed rear end for our trucks; now that would be cool
Old Dec 30, 2011 | 07:39 PM
whiskers's Avatar
I have uswed the gear vendors in 4 different trucks. The one I have now has over 100k on it and still works perfect. All behind Dodge diesels. And I tow 25k per year pulling my 5th wheel. They will give you a big advantage in gearing for those 4:10's. They are a 20% reduction in rpm's at any given gear. You'll have all the power you need for hard grades and heavy loads, and greater mileage for the highway. I certainly wouldn't run an automatic without it, and even my 5spds.
Old Dec 31, 2011 | 12:08 AM
Robert Rausch's Avatar
For $650 I bought a good, used 2002 disc brake rear end with Posi and put it under my truck. It was a 3.54 ratio.
The torque curve on our engines maxes out at about 1,600 rpm--above that you lose efficiency AND air resistance increases.
Old Jan 4, 2012 | 01:21 AM
12VDislePWR's Avatar
i would say do 5spd change, thats about normal withthe 4.10s with the 3.54 doin aboot 70 im at 2000 rpms. the thing aboot 4.10s you can dam# near tow down a house with em. i think it would be worth it in the long run, it would be more of a highway rig and can still tow well
Old Jan 4, 2012 | 08:31 AM
Nice steal on the axle - If I could have found one at that price I would have done it as well.
On torque, etc : yeah, that is the short of it. On most vehicles, cars/trucks/suvs whatever, the air resistance starts to outweigh the frictional losses somewhere between 45 and 55 MPH. With a camper, it will be sooner yet, and air losses stack up very fast. Speed reduction, and its counterpart of keeping the engine under 2K RPM's will help quite a bit. Under 1750 is even better, but may get you shot at on a Cali highway.
You have to find your own balance of sanity and cost : getting where you are going sooner vs having more to spend when you get there.
