shifting too early
Old May 12, 2006 | 05:55 PM
jbsmallmouth's Avatar
shifting too early
sometimes when I take off it tries to take off in 2nd gear. I can manually downshift into 1st. going through a parking lot slow in Drive it will act like it is trying to shift back and forth between 1st and 2nd. Any one else ever had this problem?
Old May 14, 2006 | 04:34 AM
mchydro's Avatar
My truck did this but I had an aftermarket valve body put in and it stopped doing it. I don't really know why but it did.
Old May 14, 2006 | 07:46 PM
bmoeller's Avatar
Replacing the governor pressure sensor and governor pressure solenoid should fix the 2nd gear starts. Worked on my stocker. Looking about about $200 in parts, from the dealer.
Old May 14, 2006 | 10:18 PM
thank you for the info. I just joined and this is my first post, so I hope I did it right.
Old May 15, 2006 | 09:45 AM
Eskimo's Avatar
Originally Posted by bmoeller
Replacing the governor pressure sensor and governor pressure solenoid should fix the 2nd gear starts. Looking about about $200 in parts, from the dealer.
Or about $130 from any transmission supply house. Check your yellow pages. Just make sure they sell new parts.
Old May 15, 2006 | 10:17 AM
berner's Avatar
You might want to check your Throttle Valve cable adjustment before you throw any money at it. An honest transmission shop could diagnose the problem and probably save you money in the long run. Good luck with it.
Old May 18, 2006 | 05:50 PM
would the pressure sensor also make it shift into 3rd and 4th early too? I try to stay off of the pedal a little on take offs, but I am propably in 4th gear at about 28-30mph, and 3rd at about 15mph. Does this sound too early?
CACalomino
20
Jun 26, 2007 07:19 PM
Big Deezul
Nov 16, 2005 12:56 PM
jrs_dodge_diesel
13
Dec 18, 2003 08:58 PM
DeaconWayne
Nov 21, 2002 11:49 AM
