Setting timing is driving me NUTS
Old Feb 21, 2007 | 08:47 PM
1workinman's Avatar
timing
Originally Posted by BigBully
Ok I set it back to the marks I made when I took it apart which I had to turn the pump about a 1/16th of an ich at the shaft and Now it is Extrememly Snappy. VEry responsive but now has an eratic idle But runs Way better. It may be just a tad to much now. I still dont understand why. I mean it has to be around 17.5* now. Has Anyone ran into anything like this?
That is where I run my 95 at 17.5 It made a huge difference. Good luck Jim
Old Feb 21, 2007 | 09:16 PM
BigBully's Avatar
Well I was thinking that But when I was setting the timing I checked the pin thing on the side of the pump and it was set at 13.5 just like Piers says my pump is supposed to be set. I suppose it could be a possibilty someone switched out the pump but it did not look like it had ever been off.
Old Feb 22, 2007 | 08:29 PM
BigBully's Avatar
So how can I tell if I have the pump I think I have?
Old Feb 22, 2007 | 08:57 PM
JKM's Avatar
JKM
Look at the tag on the side of it there will be a bunch of numbers If it is a 215 pump one of those numbers will end in 887 or 913 , if those are not there somewhere , you have something else. I used to have a reference for all the different pump ID's that came in dodges , but I can't seem to find it now.
Old Feb 22, 2007 | 09:34 PM
BigBully's Avatar
Ok the tag on the side has a gazzillion numbers
First Line is PES6P120A120RS7369
Second Line 0 402 736 913
Third line 67200 04712
Old Feb 22, 2007 | 09:37 PM
ratsun's Avatar
Second line
last 3 numbers
913 = 215hp
jrs_dodge_diesel
24
Apr 18, 2005 06:58 PM
Cowhand
Mar 10, 2005 07:09 PM
BigBlue
14
Jan 21, 2005 04:24 PM
jimjawz
Jan 2, 2005 12:23 PM
admin
Jan 19, 2003 08:35 AM
