Set timing to 16 degrees?
Old Aug 23, 2003 | 08:24 PM
jeffmet's Avatar
I have seen several topics discuss setting the timing to 15 or 16 deg to get better fuel mileage and more power. If this is so why doesn't it come closer to the 16 degrees from the factor? How much power & fuel mileage can you expect?
Old Aug 23, 2003 | 08:58 PM
dodgeman01's Avatar
Re:Set timing to 16 degrees?
[quote author=jeffmet link=board=16;threadid=18771;start=0#msg176082 date=1061688242]
[/quote]
because they pollute more I think.
DM01
Old Aug 24, 2003 | 03:04 PM
pwknapp's Avatar
Same reason they don't let them out the door @ about 500hp !! ;D
Old Aug 24, 2003 | 07:59 PM
Jim Fulmer's Avatar
If you have the head gasket to handle it 18 is better, if you have allot of fuel 20 is the best overall.......and I have proved it on the dyno......FYI.
Jim
Old Aug 24, 2003 | 08:02 PM
dodgeman01's Avatar
[quote author=Jim Fulmer link=board=16;threadid=18771;start=0#msg176261 date=1061773164]
Jim
[/quote]
I thought the further you up the timming the worse it runs on the bottom? is that true or can you have a daily driver/5er puller set at 20?
DM01
Old Aug 25, 2003 | 01:19 PM
Jim Fulmer's Avatar
The bottom end does go away with timing....true. Talking with Piers he set's his at 18 if he is going to tow but normally runs around 20, towing at 20 or more creates too much cyl pressure and 18 would only work with a good gasket I just don't tow.
Jim
Old Aug 25, 2003 | 05:15 PM
dodgeman01's Avatar
"good" gasket? what would you call a good gasket? what if the head was o-ringed?
DM01
Old Aug 25, 2003 | 09:26 PM
Jim Fulmer's Avatar
That's what I run, an O-ringed head with a .020 Marine gasket, there good to 70-75 psi after that you need to get some crazy C-ring stuff like Battering Ram did.
Jim
Old Aug 25, 2003 | 09:46 PM
dodgeman01's Avatar
[quote author=Jim Fulmer link=board=16;threadid=18771;start=0#msg176677 date=1061864802]
Jim
[/quote]
how much does the c-ring cost? how is a C ring better than a o-ring?
DM01 :
Old Aug 26, 2003 | 06:10 PM
Jim Fulmer's Avatar
http://www.haisleymachine.com/Head%2...p;%20Studs.htm
Don't know much about the C-rings and don't really want to as I have no need.
Jim
Old Aug 27, 2003 | 12:14 AM
TxDieselKid's Avatar
https://www.dieseltruckresource.com/...18103;start=75
That is the page that Battering_Baldness talks about his new setup. It's a nice looking deal. He talks about it, ask him a question, I'm sure he will answer.
Andrew
Old Aug 30, 2003 | 12:10 AM
1dslram's Avatar
I am running 19* on the street as a daily driver and am having no problems, from the timing. Now the fueling is another matter, but that is about to be fixed. PDR head,cam and twins, should do it.
Bruce
Old Aug 30, 2003 | 07:09 AM
Mostwanted's Avatar
if I get mine timed, will I get better fuel mileage and more top end?
Old Aug 30, 2003 | 11:38 AM
Jim Fulmer's Avatar
Yes, both will come up!
Old Sep 1, 2003 | 11:03 PM
kingofdodge7131's Avatar
whats the average mileage at 20?
