Serpentine belt squeek when shutdown?
Old Dec 25, 2007 | 07:47 PM
Opacity's Avatar
When I first got the truck, the belt would squeek only when the engine was shutdown, so I replaced the serpentine belt with one from NAPA it was $49.99. It was fine for about 3 shut downs, no squeek at all. Now it is back. Is this normal for 12 valve engines? I've heard only one other 94-98 CTD engine do this when shutdown, is it a common problem with the automatic tensioner?
Old Dec 25, 2007 | 08:09 PM
kyachovitz's Avatar
I wondered the same thing also and found this info.
"Cummins says this noise is normal and is caused by the engine stopping faster than the belt can. High compression says "whoa" while the fan says "go". The result is a chirp from the pully. If the viscous fan clutch is locked up at shutdown, the chirp may be heard in the next country. Belt wear and tensioner condition will also determine the decibel rating of your chirp. The chirp situation is not as common on 24-valve engines."
I doubt you have anything to worry about. Hope that helps!
Old Dec 25, 2007 | 08:18 PM
04smoker's Avatar
Smile
The third gens do that as well. I also agree that the engine is rite now! shut off but the accessories are still in drive. I think that is nothing to worry about myself.
Old Dec 25, 2007 | 08:58 PM
Sidewinder's Avatar
Very common! Try doing a search if you really want more information. Many say the Goodyear Gatorback belt stops the squeek.
Old Dec 26, 2007 | 08:22 AM
berner's Avatar
I put a Gatorback belt on. No more squeak.
Old Dec 26, 2007 | 08:35 AM
macattack_ga's Avatar
Yup. Goodyear Gatorback belt stops the squeek... so far.
Old Dec 26, 2007 | 01:08 PM
steveh1155's Avatar
Mines been chirping when I shutdown ever since I drove it off the dealers lot back in '95 - with new and old belts - wish that was the only problem I ever had! It's absolutely normal.
Old Dec 26, 2007 | 08:26 PM
thewished's Avatar
2,000 miles on my gator back belt and still no "chirp"
Old Dec 27, 2007 | 01:22 PM
patdaly's Avatar
I kinda like the "Cummins chirp".....
Old Dec 27, 2007 | 02:42 PM
Opacity's Avatar
It's embarassing, it makes me look like I don't know my elbow from my ******* when it comes to vehicles, and it's just about the opposite.
Gator back it is!!
Thanks guys!
Old Dec 27, 2007 | 04:47 PM
wcbcruzer's Avatar
I like the chirp too. It tells me my engine is still holding good compression. If it's not there then it's time for a new belt or I should start worrying.
Old Dec 30, 2007 | 07:36 PM
rmjim's Avatar
58,000 and still no chirp
Old Dec 30, 2007 | 08:44 PM
Tate's Avatar
If the gatorback doesn't fix you up, a dual disc clutch will. Its a common thing with the autos. The manuals have a lot more rotating mass to slow down, so chirps are less common. Mine chirped once before the DD, now there is no hope for it to do it again.
Old Dec 30, 2007 | 10:42 PM
running4bhs's Avatar
I also run the Goodyear Gatorback belt and that got rid of my chirp that I wasn’t even trying to get rid of just needed a new belt.
Old Dec 31, 2007 | 04:52 AM
Opacity's Avatar
I'm just ****** I ****** away $50 on a pos napa belt.
Story of my life.
