rpm going up and down
Old Jun 2, 2005 | 07:56 PM
bigE's Avatar
Unhappy rpm going up and down
rpm surging, spent 600.00 replaceing silinoids, did good for about two weeks then started back doing the same thing .raised the hood the battery cable was off. cleaned them up did fine for about 6 months.then got the frount 4 wheel drive seals replaced and a new seal in the rear end started back doing the same thing when i picked it up. this is a 98 2500 4x4 .does this truck have a tps sensor and is the abs the brake switch.
Old Jun 2, 2005 | 08:14 PM
bigE's Avatar
Unhappy rpm
well the picture realy fits. i didnt realize i was in the wrong forum.this is new to me.
Old Jun 2, 2005 | 09:35 PM
kandgo's Avatar
https://www.dieseltruckresource.com/...&highlight=tps Here you go. Goodluck,,Rick
Old Jun 2, 2005 | 09:38 PM
kandgo's Avatar
If you would like to look at photos of a split tps, go to member pappyman photo gallery. Goodluck,,Rick
Old Jun 3, 2005 | 01:17 PM
MCummings's Avatar
Are you sure the Air conditioning compressor isn't cycling on and off??
Merrick
Old Jun 4, 2005 | 08:17 AM
pappyman's Avatar
I have found the photos of the TPS repair and put them in my gallery
1) remove tps from engine
2) drill a hole 1/4" from the bottom of the cover with a 1/8" bit keep the drilling shavings outta the tps
3) spray contact cleaner into the hole and work the shaft
4) seal the hole with silicone
5) install the tps back onto the engine
6) if needed adjust the tps voltage
Its been almost a year since I did this TPS repair and its still working like it should.....this is a simple fix for a costly part that causes allot of engine RPM hunting problems by locking and unlocking the torque converter
Old Jun 4, 2005 | 01:05 PM
Fueling around's Avatar
I assume you have a 24 valve
Clean all the ground points and check the PCM, pump & APPS connectors.
What have you replaced?
Checked fuel pressure?
Old Jul 17, 2005 | 09:07 PM
bigE's Avatar
rpm spike
took my truck to turbo electric . he said it showed a transmission code ,but he didn,t know about transmissions. so took it to dodge dealer ,he scanded it and said that jiffey lube put the wrong air filter in it and it was starving for air .he also said it showed a turbo wast gate code,another 140.00bucks,sofar i spent 600.00 on transmission, 1800.00 on fuelinjectors an pump" dodge dealer" , 800.00 to put new seals in axels.i guess i,ll go to a/m turbo tomorrow and see how much they want. know wounder why people buy toyotas.
Old Jul 18, 2005 | 06:41 AM
j-fox's Avatar
The first thing anyone with a hunting trans (47RE )should do is the noise filter.
The electrical noise on these trucks is terrible. I guess I should qualify this a little more. Hunting in OD or the lock-up.
cgoaks77
Mar 19, 2009 09:23 PM
53 willys
31
Jan 31, 2008 02:24 PM
bauer500
Nov 15, 2004 04:24 PM
dieselnewbie
Apr 13, 2004 12:00 AM
fishin fever
Feb 22, 2004 08:32 PM
