Rear end swap
Old Jul 4, 2006 | 11:34 AM
2Rams's Avatar
Rear end swap
I did a search but didn't really find out what I wanted. I have a '95 4x4 I plow snow with. I'd like to put a flat/dump bed on it to haul leaves, mulch, salt spreader etc. I would like to know if I find a rear end from a dually of around the same year (94 to 97) would it be a direct bolt in. or would it be to much of a hassle.
Thanks
Steve
Old Jul 5, 2006 | 09:05 AM
gunracer1's Avatar
it will bolt in, but you need the u bolts and lower plates. and you can use one from 94 to 02 but to use a late model with disk brakes will require a lot more parts.
Old Jul 5, 2006 | 01:21 PM
2Rams's Avatar
Thank you sir. That is the info I was looking for.
Old Jul 5, 2006 | 01:59 PM
gunracer1's Avatar
if your truck is a auto with a dana 70 you will need to shorten the rear drive shaft a inch and a half. if i remember right.
Old Jul 6, 2006 | 05:25 PM
2Rams's Avatar
Would I be able to use the drive shaft from the 1 ton or are the u-joints different size.
2500CTD
Oct 19, 2010 07:10 PM
doorguy
Jun 8, 2007 06:19 AM
TEDHRS
Sep 8, 2004 03:04 AM
BIGHEAD
Jun 24, 2004 07:08 PM
CAPTDASH
Jan 15, 2004 05:06 PM
