Question?
Old May 25, 2003 | 02:38 PM
powerwagon440's Avatar
Question?
my buddy has a 95 2500 ext cab 2wd ctd. and he was wondering why when the truck is in drive and u hit the go pedal and let off real fast the engine dies? thanks!
Old May 25, 2003 | 09:09 PM
RCW's Avatar
RCW
Re:Question?
It can be one of three causes. The idle is too low due to dirty injectors or a bad idle adjustment. The cable between the transmission valve body and fuel injection pump is misadjusted. A dirty or bad TPS (throttle position sensor).<br><br>I would lean toward dirty injectors after a winter of using diesel blended with old jet fuel. It puts quite a bit of wax and deposits on the nozzles. It is a good idea for the fuel system to be cleaned with a top notch injection cleaner every spring.
Old May 26, 2003 | 09:59 AM
Re:Question?
i forgot to mention it has 233k miles on her! has a newer lift pump i think that is all that has been done to it? oil and fuel filter change recently. his tranny was shifting in and out of od alot i told him tps was dirty, bad, or not adjusted right then he had a tranny fuild change and it hasnt done it for awhile now.
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
