pitman arm
Old Sep 12, 2007 | 05:51 PM
siebertl's Avatar
pitman arm
checked out the front end today, all joints compress toward eachother, up and down. I did find a little slop in the pitman arm. Should I just go with the stock replacement?
Is it normal for all other joints to compress?
Old Sep 12, 2007 | 09:17 PM
J_T's Avatar
J_T
I don't know about up and down but if you watch them while someone turns the steering back and forth you will see slop if it's there. and I'm sure I don't have to mention the trackbar joints.
Old Sep 12, 2007 | 11:02 PM
siebertl's Avatar
loose *****
Well, they all move. Every joint in the steering linkage moves when I have someone saw the wheel. They move toward one another though, and do not exude a shearing movement, more of a compression movement. The pitman arm does have some shearing play, so it's going to get replaced.
next is the track bar and maybe a ssi.
Old Sep 13, 2007 | 08:10 PM
cheapskate's Avatar
have fun. i just did mine and it really wanted to stay where it was. broke two pitman arm pullers.
Old Sep 15, 2007 | 04:44 PM
siebertl's Avatar
arm or box?
Trying to tighten up the steering. The only thing that moves under the front end is the pitman arm. Only it moves up and down. The sector shaft may have a very small amount of shear but I took the pitman arm bolt off and the arm came right off the shaft. I mearly had to tug a little w/ my hand. So should I replace the steering box or the pitman arm. The only reason I hesitate to replace the pitman arm is that it is comprimised of nothing more than a chunck of iron. Could the pitman arm really be worn?
Old Sep 15, 2007 | 05:22 PM
dieselman2300's Avatar
It took a 20 ton shop press and a oxy/act. torch, getting the pitman female splined part red hot before it came off. It popped so loud my Brothers wife came out running to the garage, because she thought something happened.
Old Sep 15, 2007 | 07:00 PM
siebertl's Avatar
20 ton press
ok, so mine is much different. It took nothing to get it off and it wobbles. I suppose I will be replacing it then. I just hope it's the arm and not the shaft.
Old Sep 15, 2007 | 09:13 PM
gmctd's Avatar
They're right - factory installation takes ~10tons to remove once the nut is off - yours prolly wobbled because it was loose - put it back on and give it a hard cinch on the breaker bar - then see if it wobbles
Old Sep 15, 2007 | 10:03 PM
siebertl's Avatar
still wobbles
yep, that was the first thing I tried. I cannot get it tight enough to keep it from wobbling. I'll be replacing it as soon as I can get the part. Still seems like a very simple hunk of iron to go bad though.
Old Sep 16, 2007 | 10:42 PM
mike_ward's Avatar
Ok, If you reinstall it and torque it down thin take the nut off and it still that loose Ill sell u a pitman arm. It must have been loose wore its self out..... If its still loose once you titen it back down.
exsanguinate
Dec 14, 2009 04:13 PM
BigDan
Jul 8, 2006 11:04 PM
BigBlue
Sep 21, 2004 09:44 PM
BigBlue
Sep 18, 2004 02:13 AM
royalnine
Jul 18, 2004 08:56 PM
